How to install PIVOT Volt stabalizer ?!!
cck2228
256
Sandakan,Sabah
I think is nensense but i wan to know the step one by one how to install!
The first thing is how? need to remove te battery connecter or not?
I jus scare if i install is still come out fire after i install the second wire.
Install (+) or (-) first???
ijnek
564
10
Johor Bahru
i also using pivot VS.
no need to remove the batt connector.
ur batt connector should have a screw which u jus need to fit in the terminal(+tive to +tive , -tive to -tive) and jus tighten the screw.
doesn't matter which 1 u install 1st.
once u connect up correctly,the VS should have a blue LED litted up.
cck2228
256
Sandakan,Sabah
Fai =
Hemmmm..... no problem man!! Where la..haha..
Are you the guy name fai also and drive A31 ?? :D:D
Joining Off the Street 5 ?
cck2228
256
Sandakan,Sabah
ijnek = erm...no need to compare to other VS.. is jus depend on your opinion :)
Just give your point 1 to 10 points..10 points for your most satisfaction!
Yupe..very simple and nice and got blue led..very special!!
When word broke about the BMW 1 Series M Coupe, many touted it as a spiritual successor to the E30 M3 with its lightness and inline engine, something that the current E90 M3 was chided with a V8 and notably larger girth compared to the older models. Once the M Coupe has hit the roads, there were whispers that it could actually be quicker than its...
