How to install PIVOT Volt stabalizer ?!!
cck2228
256
Sandakan,Sabah
I think is nensense but i wan to know the step one by one how to install!
The first thing is how? need to remove te battery connecter or not?
I jus scare if i install is still come out fire after i install the second wire.
Install (+) or (-) first???
ijnek
564
10
Johor Bahru
i also using pivot VS.
no need to remove the batt connector.
ur batt connector should have a screw which u jus need to fit in the terminal(+tive to +tive , -tive to -tive) and jus tighten the screw.
doesn't matter which 1 u install 1st.
once u connect up correctly,the VS should have a blue LED litted up.
cck2228
256
Sandakan,Sabah
Fai =
Hemmmm..... no problem man!! Where la..haha..
Are you the guy name fai also and drive A31 ?? :D:D
Joining Off the Street 5 ?
cck2228
256
Sandakan,Sabah
ijnek = erm...no need to compare to other VS.. is jus depend on your opinion :)
Just give your point 1 to 10 points..10 points for your most satisfaction!
Yupe..very simple and nice and got blue led..very special!!
For the last part of 'The Dummies Guide', I'm going to talk about probably the most expensive of the lot - forced induction (FI). Generally speaking there are two types of FI :
1. Supercharging
2. Turbo charging
(And in some really adventurous cases, super-turbo-charging. Not for the feint hearted or the weak wallet)
The reason why I say this is the most expensive modification is this : I don't believe in...
