how much for straight pipe? remove cat con
charsiewriceboy
Jan 28, 2011
29
503
I wonder how much is it roughly to remove cat con on my stock wira 1.5gli manual.?
and replace it with a straight pipe . The exhaust currently running stock most likely with a s flow muffler in place.?
So when they said straight pipe means ...replacing the cat con with a straight pipe all the way to the s flow muffler or what?
sorry after reading so many post about exhaust im still clueless..
DanzEterna
15,911
3,371
3,213
PJ
www.primeperdanaclub.com
if u wan normal ones, can go to wei yip exhaust....
now cheap edi...bout rm200++ straight pipe + exhaust. at the same time they will remove your cat con as well.
or u could call kweng84 & go to his shop.
kumar22mostwanted
1,562
152
HELL!!!
wow i thought it would be cheaper like about rm 50.00 to remove cat con and replace it with a straight pipe ?
not that cheap because u must count the cost of labour plus material must welding back and all then if you want stainles steel could be more expensive
charsiewriceboy
29
503
HI guys,
I finally went into exhaust shop nearby to LRT Taman Bahagia facing the Taman Megah Road...and it only cost RM 30 -40 .
so @Kumar22mostwanted : I wonder have u done it before in order to give me advice on the cost. ? but thanks for your willingess to answer.
although 30 - 40 RM , the sifu was honest ....he took out the cat con ...replace it with a stainless steel pipe and welded it back to replace it....work was good...and i was suprised by the pricing..
kumar22mostwanted
1,562
152
HELL!!!
HI guys,
yeah i did mine just recently but mine was one shot replace the whole exhaust system to stainless steel 3 inch piping and it cost me rm900 in total so thats why i assumed it would cost a lot more than rm50 but it good you got it done so cheap plus he replaced it with stainless steel pipe which is very good :biggrin:
nice job
charsiewriceboy
29
503
@ kumar : sorry if i sounded unappreciative...i guess the cost is because it is 3 inch piping from extractor straight down ..but this shouldn't cost for 900 unless u are including cost of bullet and a new extractor?
mine ...is just replacing the gap between the cat con and exhaust ...so which is why probably much cheaper.
kumar22mostwanted
1,562
152
HELL!!!
no problemos yeah i knew it wouldnt cost 900 for sure lah :biggrin: that would be daylight robbery
but i wasnt sure how much your place would charge so i just put the max amount possible that could be charged at any place
anyways ive learnt the cost now which is good info for me :rolleyes:
ahkiang
80
i have removed mine Cat con too and replaced it with the straight pipe with silencer. Cost me RM250. No increase in the exhaust sound and not much different i can feel. Still monitoring the FC.
It was an action-packed day at Round 4 of the 2016 Lamborghini Blancpain Super Trofeo Asia series. The race set-off last Sunday with temperature in the low 90s (Fahrenheit) and typical sunny skies.
Held in Malaysia's world famous F1 circuit, the two-race format saw competitive action performed by all teams and drivers, but it was a double-win for local driver Afiq Yazid and...
