how much for straight pipe? remove cat con
charsiewriceboy
Jan 28, 2011
29
503
I wonder how much is it roughly to remove cat con on my stock wira 1.5gli manual.?
and replace it with a straight pipe . The exhaust currently running stock most likely with a s flow muffler in place.?
So when they said straight pipe means ...replacing the cat con with a straight pipe all the way to the s flow muffler or what?
sorry after reading so many post about exhaust im still clueless..
DanzEterna
15,911
3,371
www.primeperdanaclub.com
if u wan normal ones, can go to wei yip exhaust....
now cheap edi...bout rm200++ straight pipe + exhaust. at the same time they will remove your cat con as well.
or u could call kweng84 & go to his shop.
kumar22mostwanted
1,562
152
HELL!!!
wow i thought it would be cheaper like about rm 50.00 to remove cat con and replace it with a straight pipe ?
not that cheap because u must count the cost of labour plus material must welding back and all then if you want stainles steel could be more expensive
charsiewriceboy
29
503
HI guys,
I finally went into exhaust shop nearby to LRT Taman Bahagia facing the Taman Megah Road...and it only cost RM 30 -40 .
so @Kumar22mostwanted : I wonder have u done it before in order to give me advice on the cost. ? but thanks for your willingess to answer.
although 30 - 40 RM , the sifu was honest ....he took out the cat con ...replace it with a stainless steel pipe and welded it back to replace it....work was good...and i was suprised by the pricing..
kumar22mostwanted
1,562
152
HELL!!!
HI guys,
yeah i did mine just recently but mine was one shot replace the whole exhaust system to stainless steel 3 inch piping and it cost me rm900 in total so thats why i assumed it would cost a lot more than rm50 but it good you got it done so cheap plus he replaced it with stainless steel pipe which is very good :biggrin:
nice job
charsiewriceboy
29
503
@ kumar : sorry if i sounded unappreciative...i guess the cost is because it is 3 inch piping from extractor straight down ..but this shouldn't cost for 900 unless u are including cost of bullet and a new extractor?
mine ...is just replacing the gap between the cat con and exhaust ...so which is why probably much cheaper.
kumar22mostwanted
1,562
152
HELL!!!
no problemos yeah i knew it wouldnt cost 900 for sure lah :biggrin: that would be daylight robbery
but i wasnt sure how much your place would charge so i just put the max amount possible that could be charged at any place
anyways ive learnt the cost now which is good info for me :rolleyes:
ahkiang
80
i have removed mine Cat con too and replaced it with the straight pipe with silencer. Cost me RM250. No increase in the exhaust sound and not much different i can feel. Still monitoring the FC.
As the saying goes, the devil really is in the details, and as Shell have not let it slip our minds, all fuels are not the same. The reason being precisely what the first quip extolls, that all the additives and engineering behind it make Shell fuels stand out.
Not one to let their words sweat it out, Shell allowed the media an exclusive tour of their refinery in Port Dickson for a sneak peek...
