[help] what happened to my HID
sam1741
1,188
hi all
i dono where to post...
hope this is not the wrong subforum
anyway... my car HID (installed by previous owner)
today act strangely.
first, the lights is like ... blinking ....
so i scare anything will happened, i switch it off a while
than switch it on again
when its on again
the lights seems like brighter than usual...
than it starts blinking again.
anyone know what could be the problem?
is it ballast? or other things?
i really a noob about HID stuff....
thanks in advance
eyong
4,083
53
1,648
Check the power supply to your HID's is sufficient. HID requires alot of power to the ballast. Also make sure the grounding too.
Any reasonable mechanic should be able to test this out.
zac
1,347
231
Johor Bahru
my voltage maintain at 14.7v all the time, but the hid also blinking...:biggrin:
but mine is china made, so didn't expect much... price does make diefference isn't it...
eyong
4,083
53
1,648
Well, most HID's are made in China anyway ... but I do know those extremely low priced China HID's lifespan is about a year to two only ... Some would fail on the bulbs, and some on the ballasts ... :banghead:
And the catch is, replacement bulbs cost almost as much as the complete unit. So, you might as well change the whole system instead :listen:
sam1741
1,188
i wan to change back to the yellow bulb
the original one.. dono how much to remove the ballast n do back the wiring
the HID is install by previous owner one..
omnikron
66
8
1,508
Hi,
just want to contrbute.
Blinking HIDs can be due to insufficient voltage or amps, the initial amp draw on a 35W HID kit is about 10+ amps and gradually drops to about 3.5 amps when it's warmed up, provided 12-13 volts.
if your electricals are checked out fine, then you have to check the bulb, i would highly recommend that you do not test a failing bulb in the open as HID bulbs will blow, you can try the same bulb on a different but same wattage ballast, if it runs then the problem lies in your ballast. if not then it's the bulb easy.
try 4300K bulbs or below, i believe most cheap bulbs are 6000k above. but 4300k bulbs are more expensive from my experience.
jeffayn
621
62
3,028
Klang
in the auto trade, the bulk is sold at same price, but i not sure the market sell one K rating differ fron each other ..
wad are the the advantages and disadvantages of port and polish?
i) Carbureator Vehicle
ii) Fuel Injection
THx!~~
