::HELP Engine dies when clutch is pressed!::
Lolo Rider
34
1,508
The West Coast
I drive a Toyota KE70.My car starts ok but then the rpm drops below 1 and the car shakes badly then eventually dies.
This also happens on the road whether the car is in gear or free gear.What could be the problem?
panaroL
64
3,008
something to do with your throttle body i guess. had the same issue with my wira back then. replaced with a new TB, problem solved.
kayour
326
41
ke70??...stock 4k engine??
no tb..just carbie:hmmmm:...so, check ur carbie...whether its has problem...4 the 1st step
mmm...i hv such experience..the problem is clutch bearing jam
changed it...then problem solve:burnout:
Few months into ownership of my lovely chilli. Owh wait, now I got overheating issues.. Noticed that if I drive hard/long enough through out the day, my oil temp starts shooting up.. stop at the traffic light or stuck in jam, water temp also rising up to 90+++.. using SARD radiator (short one), not sure if it’s helping or worth pointing out but I feel the need to install a oil cooler ady.. if not no fun driving the car.. *insert frown face*
