Accidentally filled diesel into petrol engine
RENESIS VIII
7,000 RPM
7,063
950
Ipoh
A friend asked me about this issue of accidentally filled in diesel into a petrol engine. He told me that his friend's Toyota Hiace has been filled with diesel when the engine is actually a petrol engine.
In such case, what needs to be done to fix this problem? The van has also been driven shortly. I know that the fuel system needs to be cleaned out but how about overhauling the engine? Is it required?
ixeo
4,788
3,080
KL, Malaysia
Nobody accidentally fills diesel in their petrol tank. And nobody accidentally gets pregnant.
Yup, I will try what bro. Danz mentioned, but how much petrol was left and how much diesel was pump in?
I am surprised he can still drive around.....lol
sweelt
Nov 6, 2016
2,306
248
663
Penang
I see before my neighbour wife pump diesel in iswara. Lot lots of white smoke....he say what to do, swallow the pain only.
If not much diesel is pump in, the petrol still runs the car. Diesel will burn off as oil aka white smoke, but if too much diesel, petrol engine will drown......hhahhahahahhahaha:biggrin:
RENESIS VIII
7,000 RPM
7,063
950
Ipoh
It is an accident apparently. Because the owner of the van borrowed it to his friend. Meanwhile for the one that borrowed the van, he thought that all vans use only diesel, so he filled it up with diesel.
if your friend is lucky, just empty out the tank & fill up with petrol & drive it around.
Not my friend actually. My friend's friend. My friend only came to me and ask about the solution for this. :biggrin:
I'm not sure how much that guy filled in. The owner of the van only realize something is wrong when there is a lot of white smoke coming out from the exhaust. And he stopped driving after realizing that.
Same case for this van. A lot of white smoke coming out. But surprisingly, why would the wife pump diesel in Iswara, there is no diesel Iswara.
Speaking of that, imagine what will happen if someone borrowed a Wira diesel for a drive and filled it in with petrol thinking it is using a petrol engine like most Wira do.:biggrin:
sweelt
Nov 6, 2016
2,306
248
663
Penang
accidentally pump diesel/petrol can happen....not why his wife pump diesel. lol....
i duno lerrr....wear rubber also can accidentally leaked. :confused:
If still can run, means not totally diesel. Just drain the tank, fill with petrol then run until the white smoke disappear, because fuel line still have the fuel mixture of diesel and petrol....:driver:
Do at your house can get free fogging.....hhahahhaha:rofl:
RENESIS VIII
7,000 RPM
7,063
950
Ipoh
Then I guess no need for an overhaul. But fuel system cleaning is not necessarily needed?
How to do at my house. I don't even know the owner.
Fuel system means hose from tank that leads to to engine. Once tank is drained and refilled, from there when in use new petrol fuel will clean the system.
Your friend's friend mah, tell him can start engine at your house.....hhahahhahaha:biggrin:
The Marketplace Top Posts
There's a new UHP candidate from Continental Tyre lately, and it's not just another Sport Contact sibling either. Yes you've heard, It's the new MC6. Short for Max Contact, The new MC series will not just replace older MC5, it takes on a new role in the world of Ultra High...
