Hi guys... Any of u guys had this fault code before? I've google'd the it and found it too technical for me.. All I now is that EGR stands for exhaust gas recirculation....
Thanks...thats what i read too..they suggest to clean the solenoid and the valve....im going to meet up Ah Wah to settle that... any of you guys had the same error code like me b4?
eh it could also be caused by vacuum hoses flying off. especially at the egr re-circulation valve which is below the throttle body slightly to the back. There are 2 vacuum hoses that comes off quite easily if not tied with cable ties.
Can read on the above.
I actually bought a bluetooth OBDII for my Chery SUV and diagnose on my own when check light came on. Register as second O2 sensor problem. Had that replaced and now ok....
hey guys i hav a budget of about 5-6k for my nissan sunny i got for free =)...
but now i'm stuck cos i'm not sure where 2 start from and how do i manage everythin under this budget...
ok 1st the problems encountered is when i drove this car back from klang without any brakes...damn dangerous i know but i was goin damn slow...i think the brake system 'keput' already...either the master cylinder o the brake booster hav 2 b replaced...
2nd problem is water leaking...tat wan should b common...
