DIY - Oil Catch Tank on CAMPRO
EGNINE
513
65
3,028
On te hose size question, the bigger the better. It makes ur engine feel lighter. AN10 would be nice. 3/8 hose also ok.
That's the reason why I'd suggest to put it on the breather->intake ram(between TB-air filter). Reason is, it doesn't disturb the Manifold Absolute Pressure. And, u can't enlarge the pipe size since there is a non return valve and the size is fixed.
i put OCT at breather - intake ram but theres not even a drop of oil in the OCT...only oil stain..thats y i tought my set up was wrong...but i surf through the net, i found that some put 2 OCT... 1 for breather-intake ram and another one PCV - intake manifold
BoxCarRacer
524
103
1,543
Johor Bahru
Same experience here. That's is also one of the reason i relocate it to the pcv - manifold instead.
Oh, forgot to mention about this earlier. When i went to my friends garage the other day, asking about the braided hose thingy, he mention that if he were to do the hose, he will close of the manifold inlet, use a T connector to connect PCV & breather hole while another hose back to the intake ram pipe.
He claim that by doing this, I will recycle the air inside the instead of clogging the manifold.
Is this true?
speed2horizon
2,798
334
1,683
Is this true?
I guess the engine will have rough idle. Haven't try it before... But, engine will need a certain air amount of air for idling during the close throttle. So, the air from the PCV will be used for idling. That's why there'll be a non return valve on the PCV.
BoxCarRacer
524
103
1,543
Johor Bahru
I think so too. I kinda hate the idea of "recycling" the air inside the rocker cover.
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
apistate
Sep 16, 2011
23
Penang
can any1 show me the pic of OCT on campro engine..i'm interested to have 1 but i dunno where should i connect it..mb with some pic from some1 aledi put it will help me to install my OCT..
hi all...
can i potong the stock spring for lower my car?
any suggestion?
i don't want to change sport spring cause my fren say it will be "Bumpy" ...
so i decide to potong the stock spring...
