DIY LSD ~
sam1741
1,188
hi everyone...
i thinkng...
we open out our differential housing
then we insert it with vicous liquid...
(like those found in vicous type LSD)
like this.. when slow...
example when we parking or turn slow
the differential will work like normal
when fast.. like one wheel loose control
then the liquid will 'stick' two side of wheel together...
so is it possible or not? :D
DRFT_240sx
890
22
5,018
not at all.... the closest u can get to what a lsd will perform is welded differentials..
sam1741
1,188
the weld one may 'explode'
if u not weld well...
plus.. it will sacrifice your turning radius.. :(
Battousai
699
www.durifto.blogspot.com
Insert 2 metal plates, spring loaded in the middle. These plates press against the spider gears forcing them to turn at the same speed.
saru-kun
307
6
PJ
saru-kun.blogspot.com
phantom grip lsd eh...the one where two blocks of hardened steel are fitted over the spider gear shaft....this is an alternative to those very expensive limited slip diffs...coz it still uses the stock open diff...
check out sportcompactcar.com...they installed one on their project nissan sentra
alternatively, you could look up mr. sirazul at powerzone ^_^
cheers
sam1741
1,188
the steel..
put on the spider gear
this means the gear wont move freely liao?
so same effect as weld the whole thing together?
can take it out easy or not? :)
Gh0sT
417
11
cardomain.com
does this means that by adding 2 plates into those spider gears i can get roughly the same performace as an LSD gearbox???
sam1741
1,188
i found their website.....
(type search 'phantom grip LSD' in google)
but..
is this product available in malaysia?
how much it cost?
ninja_iga
3,376
guys guys
relax and slow down le
not easy to take out till the spider gears part, need to strip gearbox out....
PowerZone sells this, for most car makes
performance? almost similar to a LSD, but that's what i heard la, not tested by me.....
for more info call the man,
Sirazul
013-360-4662
PS. Pls pls mention you heard this from me and ZeroToHhundred.com :)
sam1741
1,188
so roughly how much is the price for that thing + installation?
if said heard from ZTH got discount? :D
sam1741
1,188
haih,...
no more credit on HP..
plus office phone cant call out... :(
The Marketplace Top Posts
Can somebody tell me the piston size for 4g91, 4g92 sohc, dohc,mivec, 4g93. Is it possible to rebore 4g91 block to fit in 4g93 piston? Any side effect or other parts need to change? Really appreciate u guys help
