DIY How to repair malfunction auto-flip side mirror
me2kimi
717
276
1,563
Puchong
Hi all, in this post I will show you what is the culprit when side mirror cannot auto-flip.
First we need to remove the mirror by pry from below. Do it carefully
Then remove 4 screw that hold side mirror cover.
Here what it will look like after that we removed the cover.
Remove 3 nuts from the inside, and the screws at the bottom.
Then we can remove another 3 screws that cover up the flip mechanism.
Here is what it look like inside the cover.
This green gear broke and loosen. So I've found the culprit. I use epoxy glue to glue up the gear to the motor shaft. You can see the crack line along the gear.
And here is another type of side mirror that have a same problem but different culprit. In this case, the culprit is clip of the cover for the flip mechanism has broke. This picture and guide are taken from Encik Rosso, that I have known from 4AEOC. He just use a cable tie to fix it. Simple yet effective.
feipepe
293
13
balakong
Mekimi bro,so i want to used your method to solve my ae101 auto flip too. Thus may i know where did u get this brand expoy glue?have any photo to share?
ken yeang
6,617
1,327
when you pry the mirror, what r the chances it wont crack the mirror, me2kimi?
me2kimi
717
276
1,563
Puchong
Bro, go to hardware shop and ask them for ARALDITE glue. But I did not recommend that brand. Just get another brand as same function.
Extra careful when you pry it. If you feel that the mirror still did not to come out, try pry from the other side
Sent from my Galaxy Nexus
goohtj
57
12
5,008
my nazaria passenger on got problem... unfolding time motor won't stop. any idea?
Dailamator
Aug 1, 2014
30
508
34
probably the position sensor bro. each mirror has a sensor to tell where the mirror is. if ur sensor is malfunctioning for one reason or another. your mirror still thinks it is not fully open or closed yet. hence it will go on forever.
Hi All ZTHians,
I've just recently started to notice a knocking sound coming from the front left suspension in my Evo 8 MR. It only happens when im going over bumps quickly, when i go over speed bumps slowly there is no knocking. The knocking was very minor at first but i can tell it is starting to get worse. I have had a look at the suspension mounts and the suspension itself but there seems to be no signs of any damage. Could it be the bushes that need replacing, would this cause the...
