Difficulty engage gear 1 vs works engineering clutch??
ken_junyi
26
singapore
Hi Bros,
Ard 5months ago I installed a works engineering 5puck racing clutch. However driving for a while, I realise my gear 1 keeps getting tougher to engage as the days go by. I check with my mechanic he said its because of the clutch no good.
No offences to works engineering but I'd like to find out if any bros here face the similar problem??? Thanks!!!
DanzEterna
15,911
3,371
www.primeperdanaclub.com
works clutch got spring like exedy ah? cos trinity ones dun have.
---------- Post added at 10:36 AM ---------- 6 hour anti-bump limit - Previous post was at 10:35 AM ----------
u got change yr gear oil recently or not?
ken_junyi
26
singapore
Yup works clutch got spring... The workshop who changed the clutch for me used torco gearbox oil. I used the high spec!
what was the gearbox oil viscosity??? (rating number)
what car? proton or perodua or else? coz i knew some perodua models quite hard to engage 1st and reverse gear.....
:adore:
ken_junyi
26
singapore
I can't remember the viscosity but If I'm not wrong they used torco gear oil GL6. I'm driving a lancer cs3 btw
---------- Post added at 11:15 AM ---------- 6 hour anti-bump limit - Previous post was at 10:52 AM ----------
scared the clutch plate no alligned properly, did u face this problem before u change to works clutch set?
Before I change clutch no problem bro. After change clutch also no problem. It's only Ard 3 months after I change clutch then start to have problem
DanzEterna
15,911
3,371
have u been thru a puddle or water recently? previously happened to me, hard to shift 1 & 3rd gear.
rupanye gbox masuk air abit...after changed MTF, everything settled.
ken_junyi
26
singapore
What is MTF bro?? Hmmm I don't recall gg through any deep puddles of water leh... But thanks anyway for your help so far!!!
i own a kia sportage year around 1997 - First model
So the Alarm remote control (Original from kia) already LOST. hence the Alarm has disable engine from Starting
Well , Starter spinning . But the SPARK PLUG has been disabled and fuel CUT OFF
I have take out ecu and check the power supply - All power supply goes in to ECU , But what else HAS BEEN CUT OFF ???
If i get to know which thing cut off and i can bypasss it . den engine START ...
anyone can help me ?
ANYONE can tell...
