cylinder boring
richardtan
97
1,508
Dear Sifus,
Can an old engine be bored to make it as good as brand new?
To what extent can an engine cylinder be refurbished to be like new?
Also, is it cost effective?
regards
Richard?
xtremeleo
3,247
464
5,183
an old engine can be bored out, u need to see the manual (if stated) on what is the maximum u can shave off, OR just bore the minimum dats needed; dat can be dependent on how much u need to shave or the available pistons selection
richardtan
97
1,508
Thank you Sifus,
does it really help make the engine nearly as good as brand new, if done correctly?
I am thinking of getting a second hand car and refurbishing the engine. But not sure if cost-effective. Thanks for reading.
regards
Richard
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
reboring and rehoning the cylinder wall... fit in new pistons... refurbish ur conrods and crankshaft... new main bearing, new conrod bearings, new piston rings, new valve seal...
all the above done with proper measurement and clearance as specified in workshop manual... i'm sure u will get a close to brand new engine after that...
hey guys,
wanna to ask about this , how can we adjust the air fuel setting to more lean to get better pick up and economy in stock 4G91 engine ?? pls advice.. Thanks :unsure:
