Oversize head cylinder valves
dfx16
107
6
Good day sifu
I tried do a search with regard oversize valves
Nothing much was discussed
What's the pro and con for increasing the diameter of the valves 1~3mm over stock
How much bhp one can expect to gain from 1.6 na or 2.0 na
Thanks
mona-vie
Mar 24, 2011
48
14
508
Singapore
Bigger valves allows more air to enter the combustion chamber. This improves power at high RPM.
However, bigger valves will also reduce air velocity at low RPM. Hence worse low RPM power.
Bigger valves alone is not useful, it needs to be used in conjunction with your cam + other mods.
dfx16
107
6
Thanks mona-vie.. i understand those principles
My concern for con for eg. will this mod cause errand idle?
And for pro what can i benefit from this mod?
upontheriversky
275
82
i would think get bigger valve along with oversized piston for power balance across rpm. need to think about fitment of the valves too
kambing69
216
33
528
the cons i think will occur overheat..or maybe dmg some of the internal parts in the engine, if it not been strengthens..
Hi,
I'm trying to upload a pic of disklok on my car but the damn upload screen keeps on telling me 39.1k is the limit. What is the problem?
