Car shaking when idle
chimaera
42
i own a wira 1.6 (m) millennium edition my car shake tedious when idle with air cond on until i can hear my dash board sound, when i press some oil (pedal) the car go back to normal.. for your information my car rpm will drop to around 600 - 700 when air cond on and start shake if the rpm to around 1100 the car back to normal....
my question is... is it normal for my car? can i set my car idle rpm to 1100 so the car won't shake so much...??
kyheng
1,202
seremban
Try 800rpm first, you can set at 1100, but petrol will be gone faster..
chimaera
42
so if i want to set it normally how much it will charge? if any one face this problem too please give more advice thanks
boosook
378
Shah Alam
its normal for a car to shake when rpm 1000 below...my car is the same too...
yes u can set it back...take to the workshop and just tell them ur rpm very low and u wan it higher...coz near ur throttle body there is a nut/screw to adjust it... i dun they will charge expensive la...just making the screw tighter oni ma...hehehe
cheers!
ryucky81
133
johore
or u can ask ur mech to adjust for u when u service ur car lo. may b u wanna check ur enjin mounting oso. it happen to me. hope this help
kyheng
1,202
seremban
Yeah, car mounting also is a cause, for carburetor car we can adust the nut/screw, but injection cannot, have to use machine to tune it. Anyway do we notice or not? When new proton wira manual when we drive is ok only, after sometime it start to vibrate or sometimes engine dead in the middle of traffic jam. Actually the timing stand 50% the other 50% is because the air intake to the injecter blocked by carbon. So when we don't know we go back to service center to increase the timing, then problem solved. This is totally wrong, on meter after adjust we see is 800rpm but actual is 1000-1100rpm already which is fuel consuming during idle. We can clean it by ourself on this. You can see after the air filter before to injecter got a joint, just take out the joint then open the spring loaded valve, after this use a clean cloth to wipe it. Finish install back and you will found the engine not that shaky. But this only applied to injection cars.
kyheng
1,202
seremban
Let all the people have more awarness on this, last time before o know this, when go to service center almost get con with rm300, but this is for cleaning the whole injection module on the car. If just 1 part blocked and we spent rm300 for it, for me better keep the money for other use, not for clean a part that will get blocked again after sometime...
chimaera
42
kyheng, i don really understand on ur tips the join u means is the rubber hose which connect from air filter to the air intake? and what is spring loaded valve
kyheng
1,202
seremban
After tune sure ok, if after tune still cannot then more problem, now you only waste abit more fuel, nothing much. Before tune actual rpm 600-800, meter show same, after tune actual 800-1000 but meter still show 600-800. In long run you will feel why FC is higher.
kyheng
1,202
seremban
Ok, I have upload the photos, sorry not that clear. From the photos you can see that there is a nut/screw that you have to open it. After you take it out you can see there is a valve that you have to open it at the back, then use a clean cloths to clean it and you will see alot of carbon on the cloth. After this you can try start back your engine and it will shake no more, or the engine die in the middle of the road....
e819
1,261
if ur using wira 2002 above.. alwez get problem wit the TB.. acct no need 2 tune oso.. just take out air filter hos n tembak wd40 inside while remm remm the engine.. coz inside the TB dirty wan.. i did it 2 few cars n its okey..
PS don kene tipu wit mech that charge over 60 bucks n tell u must tune back.. as long u just cuci2 a bit n dont touch anything else.. its fine.. my 2 sen
The Marketplace Top Posts
SUBANG JAYA: A 28-year-old computer engineering assistant, who was hit on the head with a steering wheel lock two days ago, succumbed to his injuries at Kuala Lumpur Hospital (HKL).
Muhammad Nazri Ismail, who is a member of the Umno Youth branch in Jalan Kenanga, Cheras, died at about 1.30am yesterday. He had a deep gash at the back of the head.
Subang Jaya deputy OCPD Supt Kamal Rosli Skymmar A. Wahab Skymmar said that at 8.30am on Tuesday, the public alerted police that a man had been...
