kenari hve screw to adjust at the Throttle Body there due to it is wire type TB. but even u adjust it wouldn't much bcoz our ecu will relearn it. Try reset ur ecu can settle the problem or not, if cannot then u need to check which problem it occur from. Just my 2cent
there is 1 ECU controling the car air,elec & fuel system...
even you adjust it also no big different...
send to workshop to ask foreman to plug in the control unit to set for you.
if can, also clean up the throttle body...before you set it back to default.
A few weeks back, we were at the launch of the new Porsche 911. You can read our report here. At the time of launch, the only prices revealed were the duty free ones - RM430,000 for the Carrera and RM490,000 for the Carrera S...
