Steering wheel shaking at high speed!
KGhee
25
1,503
Weird, i just got my car tires balanced and alignment done a few days ago. When i'm driving above 90km/h...the steering just vibrates all the way to 120km/h! I didn't had such bad vibrations (there was some minor vibration from ~90-100, but after that...it was pretty smooth) prior to the tires service. Any idea on what might be wrong? Appreciate your advices here.
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
I have this problem wif my kancil.... when i go my friendly tyre shop, they say need to do hi speed balancing and they dun have the tools to do it ....
went to tekming in sunway the next day and they say they do it... silly me for not seeing how or what this "hi speed balancing" is all about...:hmmmm: too busy gawking at the rims collection there... :rofl:
Ivan54
59
1,508
quite afew possibilities.but i would suggest you check your tires for uneven wear 1st.then slowly narrow down to possibilities like out of shape rims.i once had the same problem due to my front left hand side rim out of shape.
hope you get ur problem solved soon and drive safe bro.
KGhee
25
1,503
As far as i know, tires wear are quite uniform (~6months old tires, and look OK to me when it was removed for balancing). Hmmm, i'll go back to the tire shop later for a quick check. Besides tire wear and out-of-shaped rims, what other possibilities could it be?
EvolutionZ
5,000 RPM
5,027
1,448
few things u need to look into
1) uneven tires wear - sometime u cant notice with our eyes, let the tires shop check
2) dented rims - it happens when u hit pot holes and have even the slightest dent, it will cause vibration too
3) balancing not proper - try do on wheel balancing.
hope it could help.
actuator_bypass
57
1) uneven tires wear - sometime u can notice with our eyes, let the tires shop check
hope it could help.
yes this is good recommendation, I 2nd that.
Im driving a wira with converted engine and rear disc brake. It seems that they only assist less than 10% of the braking. The rear disc brake pads are rarely change, the disc looks smooth & there is no cove at the tip of the disc. means it has never really been use. i was hoping to get hand brake stop effect at 80km +, but mech says it not possible. any advice ??
