Can any 1 teach me how to install a blow off valve for triton
infusio
44
N.sembilan
Halo bro....
Can any help me....
I have a mitsubishi triton l200
i have just installed a blowoff valve but it does not blowoff
do any of u guys know wer to coonect the pressure pipe.
speed2horizon
2,798
334
1,683
Halo bro....
Can any help me....
there's a srock CBV connected betweent the intercooler pipe and the compressor intake ramp. Close up the hole on the compressor intake ramp. mount the BOV on the intercooler piping. connect a vacumn hose between the intake manifold onto your BOV small nipple on the top.
It should sound when u release ur throttle. beware cuz car that uses MAF might cause stall as an effect of improper AFR due to the measured air discharged.
Zeroed
1,705
45
I believe it wont work on a diesel.
Diesel engines dont use throttle bodies...
then how diesel control air-flow level prior to throttle ah??
seriously i didn't really know turbo-diesel setup :adore:
wesley12
7
Sandakan
From what I know, Diesel engines are usually played with an external wastegate with electronic intergrated boost control as a form of discharging compressed air... BOV can be fixed too, but you must fix the BOV according to the boost pressure of the turbo..
Just my honest opinion, screw the BOV, makes a diesel car sound fake.. XD
I prefer wastegate as a form of discharging and on the plus side, its best at controlling the boost pressure.. n the shush shush shush sound kicks in when u let go of the throttle.. Sexay~
Check out this video, it may help u explain how u should tune ur BOV:
YouTube - Mighty Car Mods - Blow Off Valves Mythbusted (SE02 EP03)
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
Veloc
3,234
991
Sabah
Diesel throttle paddle controls the fuel injection directly... That being said, I've heard diesel car having some sound during gear change. Not clean short sound like the BOV's (Pishh). Also like a blowing sound but it last longer... Hmm...
if a 4g92p auto wanna change to manual.roughly how much do i have to spent for the conversion?price of the manual gb.auto shud be more expensive right?is there a possibility that i could get a 0-0 trade for a manual?and also...is it possible to fix in a tiptronic into a satria?i'm just curious to know if it's possible....if can expensive or not?
thanks in advance
