100hp was very easy to gain on 660cc block... as 660blok that is usual L2 block laa kan?
so, here, as your request to get 100hp, only a little (consider little) modification for me..
1) bigger turbo
2) bigger injector
3) bigger fuel pump
4) fuel regulator
5) a steady good clutch
6) piggyback
7) bigger intercooler (optional)
my old.. very2 old spec that im using gain 117hp
1) turbo = td04-09 (from pajero diesel ) = **RM450
2) injector = 240cc (from vr4 na or maybe perdana SE) ** RM100-150
or 295cc from charade gtti *if im not mistaken
3) fuel pump ( gsr, evo, sr20, rb20 *this is internal pump) or maybe u can use external such as walbro, bosch etc etc **RM150-300
4) fuel regulator **RM 200-350
5) clutch ( last time im using triniti racing clutch with custom double pressure plate ) **RM600 for clutch n double pressure
6) piggyback (im just using safc 1 bluscreen because no money to buy e-manage) **RM600 - 700 for safc
7) intercoller ( im using vr4 ) *optional RM1000 including stainless steel piping with samco
thats all my old setting... 117hp on 660cc @ 1.5bar.. ok laaa .. im very satisfied with this setup.. *tahun 2007punya cerita laa ni...
then after a while, air naik kepala, 246hp on 660cc ..
u at penang? owhhh, i can suggest u at this one workshop.. last time they use to drag at batu kawan... very nice pomen.. but at permatang pauh laa...
remember, great power come great responsibility!
aiya.. dont forget to have a good n bigger exhaust piping... 1.8-2inch is ok.. dont go to big later no backpressure pulak!
