Brand New BMW X5 iDrive CBU whacked before delivery
kc2
1,354
1,410
thedetailers.blogspot.com
This is one of the first few X5 CBU units deliver end of last year,
I was called to attend to protecting this awesome ride, .......................
some pictures taken during wash
stained side steps
more stains from side steps, cant believe from a new car??? new car doesnt means just built...this is a CBU unit , for it came a long long way! shipment from Germany, by sea, held up at custom dock till it is clear, then drove to stock yard, then deliver to state dealer and thus the local dealer
imagine the amount of contaminats it was exposed to
brushing away with OPC
more stains discover at every rubber anti slip area
mnnnnnnnnnnnnn.....lots of work
here is a clearer evident
ta da
the culprit ....anti rust dropping ....stained ....
anti rust ...is applied to the inner door body to prevent rust, some how when it is melt...it stained everywhere like a glue or chewing gum
ta da....after much cleaning
https://lh3.googleusercontent.com/-9NygZnhuT_E/U8xqbNS1EvI/AAAAAAAAFVg/XN7TRJuZdCw/s576-Ic42/IMG_0289.JPG/img]
many would not have imagine why? and even some may ask why does a new car must be detail prior delivery
some of you may have many answers....eg
the car from Germany Manufacturing plant produce and kept the stock in the yard, later was transfers to dock at harbor! boarded the ship hence....arriving to bonded area! later transfers to HQ/ Capital stock yard and hence fort to dealer branch ...being exposed to many sun rain in the open area
the contaminant from rain and industrial fall out may have smear and created some contaminant/stains
henceforth was sent to a detailer....ended whacked while it being detail
see it for yourself grease like anti rust
[img]https://lh3.googleusercontent.com/-pLGJj7A2glw/U8xp0nG40TI/AAAAAAAAFSI/HQRobNR0Gzo/s576-Ic42/IMG_0262.JPG
ta daaaaaaaaaaaaaaaaaaaaaaaa
more
ta da
cleaning the wheels by Harold
carefully and meticulously
as we want to protect the car from top to bottom, outside to inside
moving to the bonnet
beneath the cover inbetween the car body and lower compartment door
seats being detail as well
door jam rubber damper before
after
whitish stain at the rubber parts
dust and dirt as well
carefully brush
cleaning the cervices
car registration was remove and these neglected area too is not spared but carefullt detail prior permemnant protection
tada
more dressing being removed
all dressing is being further remove
tada
moving to engine bay
clean by OPC to ensure every grease or oil film be remove prior coating
moving into the heart
every part carefully clean prior coating to be application for maximum protection
be warn....even BMW hood can be of risk of falling dwon to your head
before...ensuring all dressing will be stripped prior application of coating
at work
before
after
about time
tada
preparing the paint surface
claying the outter contaminations
later was carefully wash and dry for paint inspections
initially we found a couples of insects saps not clean carefully
what i picked up during close up paint inspection
scratchhhhhhhhhhhhhhhhhhhhhhhhhhh
close up
macro
from here
some scuff
scratch
scratchhhhhhhhhhhhhhhhhhhhhhhhhhh...this is long
tada...after careful correction
before
ta da
careful inspection by 300 watt halogen light ..imitatding the sun without the heat
close up
tada
before
now
camera
before
tada
after
finishing
what alovely day
tada ...its a reflection
tada another decoy
careful inspection after finish
opsssss...some paint smear
at the rear driver wheel arch
a layer of film inside the headlamp!!!!!
wonder how it ended up there
tadaaaaa
hood
interior
ensure every part of being carefully cleaned prior application of permenant priotection by coating
center plastic window frame cover before
wirls from improper washing
tada
driver side centre piece corrected as well
opsssss....window stains
ehhhh
use a damp cloth to do a spot check for stains
i wouldnt sure if I would do the glass coating on these stains
before
after correction by polishing
always
final inspection
side step now ready for permemant protection coating
no more tears
after coating
head lamp
lets wefie
some finishing photo
i am amazed to see how a 3 years old F10 ///M5 coated ...still looks goood....to read more here
Car detailer: Stunning results of BMW F10 M5 after 4 years OPTI coating
E92 ///M3....awesome looking
this is a 2 years coated a pearl white super fast ride still looking good
thanks for viewing yet another detailing journey of me, hope you had as much fun as I blog
© 2015 KC thedetailers.blogspot.com (United States of Detailers)
Hi, recently i've asked about how do i need to modify on my Waja 4g18 exhaust system, a sifu suggested me to change the extrator to 4-2-1 and mid box only.
is that enough to gain the performance that i needed already? exclude the sound or whatever muffler that are for cosmetic purpose only. thanks
