Water mark! Water spots! water etching on your paint! worst of all on a Brand New Mercedes C250 CGI
please place your car at night and check for such spot under street lamp.....especially wipe test with a damp cloth
Mercedes-Benz C 250 CGI
The letters ‘CGI’ are ‘Benz-Speak’ for direct fuel injection
most famous star
‘BlueEFFICIENCY’ – the name given to its efforts to reduce energy consumption. And when the German giant tackles an engineering challenge, historically the results have been spectacular.
PROS
Superb interior and exterior style; BlueEFFICIENCY technology
CONS
No reversing camera; lacks low-down throttle response
always begin body prep with clay after proper wash down
Water mark is a huge problem in our country because of the mineral content in the water and acid rains . You may have noticed those nasty spots just won’t come off after you have rinsed off your vehicle or your car during wash.
Water mark are caused water supply JPA, roofing tiles washed down, leaking of car park ceiling and acid rain! these mineral even stains all coated car - The water needs to be wiped off and dried to prevent water spotting. . OPTI COAT as well
WASH - OCS with All Purpose cleaner to strip away any pre existing wax
SURFACE PREP - Clay with onr as lube
Wipe down with - ONR as QD
Paint correction - initial - Makita M9227 with polish pad...wouldnt able to resolve water mark
Move to heavier correction combination - OPT Cutting Pad with Meguairs M101 at 1200-1500 rpm
Finish with Flex Meguairs - Soft buff foam pad with Meguairs M205
water marks
more mineral deposit
If this left on the surface the sun will evaporate the water leaving only the minerals behind. These minerals will adhere, or worse, “etch” into the paint surface and bond with the paint causing an unsightly blemish ring, or water spot.
water mark
mineral deposit from wash down roof mineral deposit
inflicted the whole car like
fungal infection
initial
failed attempt - polishing and retry
retry
spot check after compounding
suscessful water mark / mineral deposit removed
interior
interior clean by ALL PURPOSE CLEANER and coated
whitish stains on the front seats
look at the water beading on the alcantara seats
tada
wheeels clean and protected
some picture to speaks of our hard work and effort
now your turn to check on your car
most famous star
PROS
CONS
water marks
water mark
fungal infection
initial
retry
interior
tada
