Alza UltraRacing set up
tIANcI
87
38
518
PeeJay
I just want to get some opinions from you guys ... I enjoy my Alza a lot, the ride is just right for our KL roads, the shocks soak up our lousy roads so well. As for its handling, I must say that its really nice, not as much body roll as the Myvi. At the moment I am keen to install the UR braces etc and would like to know:
1. Is it worth it to go with a full set?
2. Would it be enough to go with the front tower strut and the front/rear sway bars?
3. Does it make that much difference for daily driving?
4. Would it cause the chassis to be too stiff that it affects the ride?
Thanks a lot!
devious17
1,664
586
Kay Ell
Oi! Where are my T shirts? :biggrin:
Fancy finding you here.
Before I answer your questions, how do you drive your ALZA ? then think of why do you need them, do you really need them?
tIANcI
87
38
518
PeeJay
Devious ... you gonna die la ... its been sitting for the longest of time. You gonna kena la. Mati la you ...
Danz ... I love your approach to the whole thing. LOL!
devious17
1,664
586
Kay Ell
hahahahah Tianci, read up vehicle chassis dynamic and once you (if) understand what you have read you would be able to make an educated decision.
tIANcI
87
38
518
PeeJay
Devious ... I have, I understand how it all works but the question is, how much will if affect the ride? Will it make the car harder on the road and if so how much?
Long ago I did add a simple shock tower strut to a mere Kancil and the handling changed a lot, even for everyday driving. This time I am wondering if they will be a lot of difference if I were to add the shock tower strut, front and back anti roll bars.
Then how effective are the bottom and side struts? :)
Hi Guys,
I've recently decided i'm not happy with the power my Evo 8 MR is making, its currently running about 320 at the wheels (although there is an issue with a lazy tappet causing it to only run at 280). I'm running high cams, straight through exhaust, blow off valve etc... I want to squeeze some more power out of the car with simple and cheap (but effective) mods. I don't want to go spending alot of money on the car and i can't run higher boost (1.8) as this has been done before and...
