sometimes voltage reading also not accurate.personally im not a fan of removing the terminals to check the voltage. when you do that the voltage will spike, some electronics are very sensitive. Best way is to use a multimeter and get the voltage readings.
if your alternator can't support the whole car and jerk and died off, I think your alternator is dyingWTA: to check alternator? if we removed one of the terminal battery, as fact car will jerk jerk burp burp the engine died off. is there any testing that newbie can do to check "health" of alternator?
Your 12.2v is with engine off right, as you mention then you start the car. If engine off 12.2 is ok but a bit on the low as correct reading is around 12.6. He should check with engine on.sometimes voltage reading also not accurate.
example my case, the wireman says detected 12.2V only and this is insufficient to support the whole car.
I then started the car + turn on radio + turn on aircond + turn on head lamp, when everything if running I removed the negative terminal, and YET THE ENGINE IS STILL RUNNING !
If the alternator is producing insufficient juice as he said, then the engine should jerk & die off.
---------- Post added at 09:42 AM ---------- 6 hour anti-bump limit - Previous post was at 09:41 AM ----------
When I off my car, it's 12.2V, when I start the engine, it's 12.2V too when the wireman tested. But when I test at home with my own meter, the reading is 13.0-13.3VYour 12.2v is with engine off right, as you mention then you start the car. If engine off 12.2 is ok but a bit on the low as correct reading is around 12.6. He should check with engine on.
If want to check the charging amp then he need to connect multi meter between removed terminal and battery...
Must be his meter konk already. On and off also same.....lolWhen I off my car, it's 12.2V, when I start the engine, it's 12.2V too when the wireman tested. But when I test at home with my own meter, the reading is 13.0-13.3V
charging amp shall check between removed terminal & battery, means the negative terminal & positive at battery ?
if the alternator can't cope with the electrical load, the engine shall die regardless it's night or day time.this is cause the alternator cant cope with the electrical load. .
When the terminal is remove and as long as no power coming from the alternator, the engine will die off.if the alternator can't cope with the electrical load, the engine shall die regardless it's night or day time.
as long as the electronic equipment you turned on exceeded the max output of the alternator, the engine shall die off immediately.
There is a case where alternator output is weak, so it will slowly drain the battery until the battery dies off. But in this case, when you remove the -ve connector, the engine shall die because it can't get the support from the battery anymore.
did you loosen your belt or applied some KY so it can't grip ?thank you friends!!
i am have another problems.. i am noobs about car..problems comes when i godek2 the alternator belting because sound of creeeeettt comes out..now ok BUT cold start my 'ayam' apexi pen timer voltage is 10.4..after revving the volt get 13.3v-13.5v. i am trying pulled out the battery terminal, engine steady(aircond on,radio on,headlamp on).
Loosen? should tighten right? Add ky will slip more.....hhahahhahadid you loosen your belt or applied some KY so it can't grip ?
tighten the belt my friend. i am using natural lubricate..kahkahkahdid you loosen your belt or applied some KY so it can't grip ?
yes brother. tighten the belt. will looking that belt dressing. tq.Loosen? should tighten right? Add ky will slip more.....hhahahhaha
Look for belt dressing or belt grip. Apply those for better grip....
