Aircond blower
DanzEterna
15,911
3,371
3,213
PJ
www.primeperdanaclub.com
guys,
my aircond for 6a12tt having problems....happened yesterday while otw back to KL from Rompin,
aircond speed was at number 1, but suddenly it was blowing very little air then back to normal.
therefore i blasted the aircond to maximum but as its like number 1 speed....
it was like that the whole journey home.....
i guess should i service the blower? could it be clogged inside or is it compressor going to kong soon?
D7zul
2,697
848
Shah Alam
since u wanna DIY a filter on it, why dont u open it up 1st & check..
mayb there's a dead rat inside.. hahaha :rofl::rofl::rofl:
joking only.. jgn marah ye :aetsch:
Veloc
3,234
991
Sabah
IF it's the fan speed the n most probably the blower only la... Compressor to make cold air. Blower to blow it out. Mayb should take to electrician and check the electrical system first. Sometimes the wire at the control panel or connecting points lose. So what ever sped you put, it just reads on or off. No speed control in between.
DanzEterna
15,911
3,371
3,213
PJ
since there is still cold air its not the
compressor
kondensor
cooling coil.
so im down with
fan - will check later
blower.
it happens on & off occasionally......
DanzEterna
15,911
3,371
3,213
PJ
update.
send to aircond specialist shop to rectify the problem....it wasnt the blower, it was not clogged with dust particles & motor working fine.
it was becos of the expansion valve needs to be changed & add on an external thermosthat. this is becos after a long journey (especially stuck in jams for a long time), the cooling coil tends to be frozen hence will block air into the blower.....something like that la the guy explained to me..well im a noob when it comes to aircond system...but im learning though....
so for now problem solved.....total costs rm340....damn!!!....
D7zul
2,697
848
Shah Alam
wah.. ur aircond can produce ice..
nice
:biggrin:
Veloc
3,234
991
Sabah
A valve... RM370??? Sakit...
Thanks for your sharing on this anyways bro!
DanzEterna
15,911
3,371
3,213
PJ
i just realised that my aircond does not have a filter.....
wattudu bro...end of this mth gonna balik kampung...so aircond must be in tiptop condition..
if not wife bising haha...
As most of you would've seen, since the Nissan Latio or known as the Tiida in Japan was recently launched here, Edaran Tan Chong Motor has been enthusiastically promoting the Latio almost everywhere. The Super GT was no exception...
