wira auto or manual? my wira auto stock is doing at near 4000rpm. 3gears only... :turtle:kevin62 said:120kmh at 3k rpm is very good already. Wira is doinf 3500rpm when 110km/h.
no....what i meant was if the tyres has been changed to 16 or 17 inches then the speedo reading would not be accurate but the rpm would still read correct...but since u dont have correct speedo reading then u cannot use that as a guide to read yr rpm reading at certain speed. but if yr tyres are of original size or very close then no problem as the speedo would read correct.SkYwAlKeR said:... will wider tyres causing my car harder to achieve top speed??...
speed dropped when in 5th gear.. interesting... not gonna get 6-gearbox liao... 5-gear is enuf i think.... at most also i think is to tune the gear only.. ok??? ok kua... :Dflamefox850 said:no problem bro..we all still learning from time to time.
what i said previously that relates the torque value and the top speed at highest gear for kelisa has been experienced by my friend that drive kelisa NA with haltech E6K and mid cam (264 deg ?? can't remember)..he's also a member of ZTH, his nickname is Kelisa187, u can PM him for more info.
if i remember correctly, last time he said to me that his kelisa can go around 170-180km/h in 4th gear but when he change to 5th gear..the speed drop from 170km/h to 160km/h and below.
that's why i said if u have the longest ratio in gear 6 also u can't get the highest top speed u want. all depends on ur engine's high rpm torque
paiseh... 120km/h mine about 3200rpm.... :Det5828 said:my kelisa can only go 100km in 3k rpm
weird
consider good lo... mine 120kmh can reach 4000rpm... :thumpdownwk1168 said:paiseh... 120km/h mine about 3200rpm.... :D
a bit off topic and a bit late reply... paiseh...kirks said:with so many kelisa models, which is which?
I wanna buy a 1K CC manual, but I damn blur dunno which is which.
Anybody with ideas?
