6-speed gearbox for kelisa possible?
gloss
1,546
SJ
go tuned ur gear ratio.... :biggrin:
kelisa no need fly so fast la...
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
yeap... coz kelisa body weight much lighter ma... plus with its 1.0L engine, sure can smoke many cars... jz tune ur gear ratio... u might sacrifice a bit of acceleration, but surely ur top speed will improve after tuning...
my problem pulak, my iswara doing 4krpm at 120kmh... anyway i can tune my gear ratio so that it travels 120kmh at about 3k-3.5krpm without much sacrificing my acceleration??... jz decrease my top gear ratio a bit rite??.. does tuning gear ratio need dyno the car as well??..
kiran84
945
dunno
this my kelisa.......
meter habis d.......
was driving with 4 people in the car....
my fren driving wira next to me said i was goin around 180+....
kelisa damn power ....gud car
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
wah... this is after tuned gear ratio??.. or some other serious mod done to the car??... fuhyoo, can fly adi... :eek:
simon
292
is that possible ?? i mean tuning the gear ratio to achieve lower rpm at higher speed ??
anyway the normal rpm for a iswara doing 120km/h shd be 3.5-3.6k only & nothing more !!! if it is showing more than yr clutch has worn out a bit or slipping. at 4k the speed shd be between 135-140km/h.
this is same for proton saga/iswara/wira 1.3 & 1.5......unless the original tyres has been swapped for something bigger ( more than 3% from the original tyre height )
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
Bro, where have u been ? Long time didnt c u posting wan...alien kidnapped already ah ? How are you ? HOws the conversion thing going ??
wk1168
76
Penang&Puchong
tune gear means? no need change the gear inside the gearbox? how much would they be to be tuned?? im noobie.. paiseh
wk1168
76
Penang&Puchong
kiran... u r extremely... crazy... i like it!
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
hmm... reply to ur questions...
not sure if my clutch worn out or not... but if i remove the CAI when travel on highway, i can achieve 140kmh at 4k+rpm..
my tyres width for front is 175 with 13" stock rim... will wider tyres causing my car harder to achieve top speed??...
kirks
22
melaka
with so many kelisa models, which is which?
I wanna buy a 1K CC manual, but I damn blur dunno which is which.
Anybody with ideas?
howiechoo
8,000 RPM
8,857
4
Bukit Jalil
i think stock gear ratio if okay..it let u had optimum pickup and also highspeed...and also fc...but if u wan more speed, y not just tune ur engine for higher power?
if u wan highspeed with low rpm, then just change ur fif gear or ur final gear ratio to lower..then u can get it...
but, if u change to much lower ratio than ori, u might not able to reach the desire speed..because ur engine had no power to push the fif gear to that speed...
did u play GT1,2,3,4 b4?
wk1168
76
Penang&Puchong
Err... whats that... im noobie... sorry....
flamefox850
590
5,018
Pasir Mas
www.geocities.com
TitanRev said:
bro, not flaming u here ah. Just want to say that torque is more on the starting to move period of the car. From what i studied, when speed increases torque reduces.
turning force or torque is strongest when a vehicle starts to move cause al the weight has to be pulled by the engine itself and against the road friction but when a vehicle is on the move it will generate an inertia force so torque is less needed cause it already has a momentum to move already. correct me if I'm wrong.
i dunno what u study but i suggest u refer most of cars dyno graph...u can see how important torque is. torque generate power (hp) that pull the car from standstill to topspeed.
u must have been confius what torque is i think :)
p/s: what u all mean by tune gear ratios ?? someone pls clarify hehe
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
ur car torque power and overall bhp must tally properly ma...
if u have all the torque also no use... cannot go fast... but if u dont have the torque to push ur car from standstill, u cant fully optimize ur car performance...
flamefox850
590
5,018
Pasir Mas
www.geocities.com
hehe got another person confuse what torque is.
FYI the formula to get HP is torque X RPM / 5252
so, the number of HP generated is depends on torque on that particular rpm bro.
when u dyno ur car, what u get is torque value and the dyno machine will calculate the HP for u. so, torque is as important as hp to move car either from standstill, or cruising, climbing hill or whatever. its just a matter of which rpm range does the engine got more torque (this translate to which rpm range the hp being generated more)
how to make my kancil faster without changing the engine or upgrading it with a turbo
