4G93 SOHC mods. Suggestions needed.
Shinjite
864
120
1,543
Klang
TB you can use Perdana Sei TB 55mm (4G92p only 50mm) and port match with the intake manifold
For upgrades can do PNP cylinder head, a nice performance street camshaft, 4G92p pistons for high compression NA setup, LCP and lastly tune it with minimum a piggyback. Should easily net you around 12x whp easily with torque in the 15x to 160Nm range. I didn't state any adjustable cam pulley is because if you manage to find a very nice camshaft that runs good at base, ACP is not needed since you are using a 4g92p ECU the rev cut should be at 6800rpm only unless you remove it by rechipping :)
hey guyz..do anybody noe where to recon mivec air con compressor? i(Recon compressor for jap engine). Heard my frenz say subang 2 got but he don noe where. Do anybody noe where? coz i have change 4 air con compressor in 1 yr.Plz pm me.thanx
