4G92 Mivec Block + 4G93 Head
wolfen
16
1,503
from what i know 4G91 t/belt not equal 4G93 t/belt due to engine block height by 20mm. correct me if i'm wrong.
Fran23
Dublin, Ireland
yes i know about the 4G93 engine block been a bit taller. but from what i know, the 4G92 DOHC mivec and 4G93 gsr take the same timing belt.
thats because the 4G92 mivec head is a bit taller, which makes up for having shorter engine block. but the 4G91 takes a smaller timing belt and the head is just about the same as gsr. so was wondering if there is any height difference between 4G91 and 4G92 engine block. if not then i need the 4G91 belt?
only difference between 4g91 and 4g92 engine block is piston size?
---------- Post added 11-14-2013 at 12:23 AM ---------- 6 hour anti-bump limit - Previous post was 11-13-2013 at 06:38 PM ----------
the 1.5 4G91 timing belt done the job
Dear Focal Point,
Good day to you!
I had just recently overhaul my 15 years car's engine (top overhaul and change piston ring) after travelling for 530,000km in my proton wira. The engine cylinder still in good shape since i have been using tufoil for many years. Thanks to tufoil to surprise my forman on such a little wear on my engine block and bearings after such millage. I change piston ring and valve seal just to reduce the engine oil consumption problem, before it was 500ml every...
