4g13 vdo
hitmie
63
can anyone help me on how to modify my 4g13 vdo engine???? some tell me it is not as same as mmc wiring..... tq
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
what u wanna upgrade??... svdo also can upgrade... all hardware are the same... only engine management is a little different... both has it's ways in tuning to produce more power....
what is ur budget and wat upgrade u have in mind??
blind_lan
33
i used 1.3vdo before..
my mod
1.change the airfilter just drop-in the K&N
2.exhaust extractor..if u have more budget then change it all set..
3.Oversize the clutch plate 8" "have to modi the flywheel"
4.etc..
after all the modi done, i have to set da ecu... although can not set to max...but still feel da different.
chris_ch3w
407
4
new website for learning not just about cars n engines.... :biggrin:
put uncle skywalker on table n chop 18 pieces wuhahaha :rofl:
Dear bros...
Yesterday I've swapped my rims to waja first edition rims.....after balancing and alignment and also adding a spacer for the rear wheel because it seem the offset is to inside kena absober.....so after that when i drive....nice but once i apply brake...i can feel vibration from the brake......why ar?? is it the rear spacer make it like that ar...previously....using 8holes rims also no problem like that and with spacer at the front summore....sigh....anyone installed waja rims...
