Cross drilled and slotted disc brakes for lancer gt
Turbohead
88
40
Perak
I have seen Lancer GT with VTTR brakes. Those can be obtained in S'pore but I'm not sure where in M'sia though. I will try to find out more.
Why would you want to upgrade the brakes though? The stock system isn't good enough?
frank_precinct
31
before i drive a satria neo with stock disc brakes. i usually drive around 180kmh each time on hiway and very scary when u hit the brake pedal as stopping distance sooooooo long.. later changed to slotted cross drilled and wallahh.. seriously, its a different feeling.
so, for practicality, i would prefer using performance discs yet maintaining the oem caliper (maybe change performance pads). make up wise, u know what look it gives to our GT..
azizi.aziz
46
1,648
my suggestion...if you wanna change to after market one...go for slotted type rather than cross drilled type..
kairigi
393
27
www.facebook.com
since u fellas talking about brakes.. u think its possible to convert my rear drums and fronts to evo 4s? pcd i know will be 114, but i was wondering whether it will fit the cj4a chassis?
Turbohead
88
40
Perak
Frank,
I was told that Quicksave (Subang Jaya) might have something that would suit your need. Try contact them at (03)56360917 and ask them about Project MU.
PabloIceman
3,083
291
1,683
hahaha ... Azizi the "crazykatak"!!! :rofl::thefinger:
To all absorber sifu. I have this WEIRD issue with mine. I drive a civic EJ8 (4 door) and i am using GAB HA (Hi/Low) adjustables which I bought from Kakimotor sunway.
My rear is set to 2 finger gap, between tire and fender. My issue is that, my left side (passenger side) is always slightly lower than my right. I tried increasing the height only on the left side, after putting the car back on the road, same thing. As of this moment, my left side, if u see the height from the absorber itself...
