RPM controlled switching- Launch/NOs/Mivec?sub injector/etc
E-Tech
1,115
256
3,183
Johor
Hi all DIYers@zth
4-5 months ago, i did some searching and finally found a guide to make this.
(Buying a Bee-R launch was out of budget.....)
My purpose was to make a DIY Launch Controller ... however since the rpm signal is adjustable,
you can trigger a 12v relay for any purpose...from cutting ignition, fuel, on sub injector, on mivec, on horn, on central locking system and etc at what ever rpm you want.
example....
Set rpm adjustment to 6000rpm, once reach 8000= horn sound...or
5500= mivec trigger... or
4000= ignition/fuel cut... or
4000= sub injector on....etc
Final product pictures...tonite upload...
Haiyo... when read already and think it was good effort pls "thanks" lah...:biggrin:
HKS-GT2835R
1,193
83
5,148
kelate
My purpose was to make a DIY Launch Controller ... however since the rpm signal is adjustable, you can trigger a 12v relay for any purpose...from cutting ignition, fuel, on sub injector, on mivec, on horn, on central locking system and etc at what ever rpm you want.
chun wehh.. keep it up!
taiko i wanna follow you.. :smokin:
E-Tech
1,115
256
3,183
Johor
full function as BeeR rev limitter??
E-tech Launch Controller... basic function yes!
Press button switch (switch or hook up to handbrake switch, or make clutch sw)
Note: if clutch switch,,,best cos can also full throttle shift..
In gear 1 which clutch full depress...
Full throttle- rpm cut where you set, tak ngam adjust...ba ba ba ba ba ba ba
Relase clucth to launch the car...
When tires have good grip, release launch button...
As i also said, can be use for many other functions...anything you want to control by RPM.
Can also use e.g as rev limitter- e.g your hot girl friend drive your fairlady.. you set 4000 rpm cut,
then she cannot more than 4000 rpm loh...:biggrin: TQ
I studies also the concept used by MSD- cutting of ignition for rev limitter/launch control..
badturz
574
Are u a electrical engineer or what? OMG u are damn good in this kind of stuff..
U can come out with own product edi man!
E-Tech
1,115
256
3,183
Johor
Don't laugh...ok..
I majored in..................History & BM
WAH HA HA HA HA....:banghead:
Anyway hope you guys enjoy my DIY...
HKS-GT2835R
1,193
83
5,148
kelate
Don't laugh...ok..
keep up the gud work buddy! :itsme:
cmng
3,289
72
interesting
how much it cost to do this ?
since i looking for rpm activated controller as well
but a question
this is activate it at certain rpm
but will it deactivate if it below the selected rpm ?
like mivec controller, at 5000rpm activated
but when it rpm drop back to 4800rpm.. do it deactivated or still activated ?
ek_elleh
562
21
KB
i remembered that beeR hav 3 dial, right??
but yours only have 1 dial..
is there any different/lack in function??
btw, you are doing great!!
E-Tech
1,115
256
3,183
Johor
interesting
how much it cost to do this ?... material cost RM60-70
but a question
this is activate it at certain rpm... and onwards (up wards)
but will it deactivate if it below the selected rpm ? (yes... below set point, no activate)
like mivec controller, at 5000rpm activated Yes, but on 5000 & >, off at <5000
Bro, clear?
cmng
3,289
72
E Tech
got it clearly
but how you determine the RPM signal ?
since there is no display to show the rpm
it is using RPM switch ?
i looking for 2 unit.. willing to make and resell it for me ?
i not E&E people.. but i looking for this kind of controller
Dear all,
Anyone encounter this before?
My car will jerk when i start the car, every 5 seconds jerk 1-2 seconds. When on aircond immediately jerk becomes more teruk.
After engine warmed up, still have slight jerk. When press accelerator, like the car dowan to go like that. Sometimes ok, sometimes dowan to go.
Send to EON, tap on the ecu reader, found nothing wrong.
Changed plug coil, problem still exist.
Can It be fuel pump problem?
