HELP! Car overheating..
VMK77
11
Hi everybody,
Need help.. my car is overheating it's a wira 1.5 carburated engine. Did an overhaul (Full) after white smoke started coming out. Just did it about a week ago. My mechanic says it's the motor oil type I should change from 10sae to a 20 sae or something like that. Everything is fine for about 20 to 30 mins but after that the temperature rises gradually to almost the red line. I've tried flushing the radiator, changing the termostat, changing the hoses, changing the fan but nothing seems to work. All this done in the past week. Change engine?
Anybody can help me? :retarded:
Elitehunter
102
radiator leaking? try checking it wit coloured radiator coolant. maybe a leakage sumwhere
VMK77
11
I check the water pump already.. Damn OEM parts.. cost so much.. and already bocor after one week!!!! Any suggestions? I mean ca use any other brand ke?
Thanks to all.
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
Thanks to all.
usually the most popular water pump replacement is GMB.cheap n reliable.try n ask the autoshop
for it.
VMK77
11
mayb while replace the new water pump, they no remove the gum at the block there nicely
Yes Taikor... you were right! I just resealed the water pump with silicone.. car run like new oledi woh..
huakenny
LB Performance
9,126
240
Kota Kinabalu
I overhaul in Likas.. Going to get a halfcut.. Please PM me for best price lah taikor.. also interested in your grounding cables man..
Lolz.....i asked u to find me ma...since i stil at kk....hard to pm price for halfcut as im not from chopshop...and i dunno wat u wan.
price is different la bro...u wan engine only, or with halfcut,...etc etc.
if u wanna go for halfcut, i wonder y u wan to overhaul...it just waste of money.
if u r really kind in transplant, u can go survey in any chopshop in kk.
once u confirmed wit the halfcut, u can let me know. we will get for u.
VMK77
11
Aiya.. only one car mah I have.. have to do it lor.. cannot take bus to work.. 12 years oledi no use bus.. I want mivec half cut.. how long you do conversion?
huakenny
LB Performance
9,126
240
Kota Kinabalu
its good if u go to see the halfcut by urself...so u can choose, u can test.....once u confirmed then only sent to my place...if i choose for u, later got problems...dunno gotta blame who..
try Ah Ming autopart, Desbil, Tilija (rare).....get the full halfcut is great :_:
if u cant find one and u really interested in mivec, then i can order for u with minimal deposit...
conversion maybe 10days like tat....(depends) as having many cars to do most of the time....
VMK77
11
Definitely want to do already, wait for some money 1st. Damn car overheating. Do everything already.. Spend more money than buying half cut...I contact you once got some money..
mamamia said:
Hi Accoustic,
I got it! 66/34 F/R weight distribution for an N16....what do you think if I try to reduce the front from 8kg/mm to 6kg/mm ?
Your comments are appreciated. Thanks!
Hi 66 is what units? pounds/feet or what ???
8kg/mm front too much lah... can reduce to 4kg/mm or so...... normal car only 2kg/mm or so....
N16 models 66% front 33% rear ... so big difference ........... wah like that I no experience wor ..... you better talk to Richard directly.
