Advice for Suspension Replacment
You'll need to ask some sellers to see if they have the RS Ultra for Iriz. They have for Exora so it should be available
When there is enough cars of that model in the market, most probably they will make for it. I was surprised my Hyundai Sonata III which is based on Mitsu engine, share the same suspension as my VR.....:driver:
If no RS Ultra look for other options la. I'm sure there's something better than stock that isn't a coilover
Wonder if those manufacturer still do rebuilt on OEM absorbers? Mine was done previously but they have made them serviceable so they still honor rebuilt on mine......
My front absorbers are on their 3rd rebuilt. First round they clamp back, second round they ask to do serviceable if going to keep the car, which I did, so now in third rebuilt in 20 years. In between for a few years was using the D2 coil overs....
Reactions: Izso
parakey
1,367
226
3 rebuilds but how often do you use the car, mileage wise in between each rebuild?
That means roughly 6-7 years per rebuild. Durability isnt bad
Yah, the front OEM set, first round rebild should be around 6 to 7 years, then 12 years, because first rebuild was when VR engine transplant, 6 to 7 years rebuild, then another 6 to 7 years later transfer to my hyundai until 2019, 3rd rebuild back to VR.
The rear original Top perfect hi lo set was used for 19 years until leak then rebuild ..... :driver:
sweelt
Nov 6, 2016
2,306
248
fuhh long lasting. Thats the diff of old days and nowadays hand work, materials.
civic EH5 (local model)
just noticed my PS fluid are low and found out that my tie rod have leaks. what are possible solution?
p/s: i've replaced whole steering rack less than 2y ago
another question from pic below... do i need to replace bush? (outer tie rod)
