KHNG940413
668
56
johor bahru
Before buying, it's best to confirm they are worn. So far, these are mere speculations
Will inspect more to confirm is rocker arm worn out only I buy. Now driving is ok lah,juz quite noise & fuel consumption is a little down compare to after adjust tappet one.
brokenjars
229
16
Kedah
If its worn out, even after adjustment the taktak sound should still be there right? If after adjustment the sound gone, then after short time it came back again, possible its because the mechanic didnt tighten it to specifications
I was thinking the same thing......lol
parakey
1,367
226
Worn rocker not just have gap. There may be alignment issues. Wear not just limited to both contact surfaces. There's also a bush where it sits onto the shaft
KHNG940413
668
56
johor bahru
Wira update
Went for checking the car and found out the thingy that push the valve is makan already.
So the boss suggested me to do a top overhaul & replace 4 exhaust valve.
All included plus labour is around Rm800 is this price normal?
KHNG940413
668
56
johor bahru
Isnt that called the rocker arm which we mentioned earlier?
Okay....what I mean is the between rocker & the valve have a thing that push the valve one. Forgot the name.
When we open up the head cover you can push the rocker arm to valve. The middle thingy gone.
parakey
1,367
226
Forgot the name... Tappet or what hahahahhaha
Sorry for my bad pronounce. If you enlarge the picture you can see the thing have makan.
Uhm, isnt that part of the valve ?
I dont think there's anything between the valve tip and the rocker arm
KHNG940413
668
56
johor bahru
I think so correct me if I am rong.
This is a sample picture you can see the valve middle have the silver thing. That's the thing missing. Like gone.hahahahaha from the picture you provide maybe is No 4? Picture 2
parakey
1,367
226
That silver round part is the actual valve itself. See the cross section diagram below
Reactions: KHNG940413
Get Dimensions
Width = 9.2
Height = 4.8
Switch
height - 1.9
width - 1.4
Get Materials.
Preferably Aluminium Sheet 0.7 mm or less. . Plexiglass might crack while cutting(Unless you have sum advanced Laser cutting machine.:p) If you're from Seremban, You can get this from Tukang besi..corner shop same row with Dunlop Tyre Shop in Temiang.. Right in front of the Traffic Light
Switches
Prepare...
