4g13 talks
Theres one shop quote me 680 for pipecam 272 degree. Wanna hear u guys punya opinion
intake 272 or exhaust? Whats the lift? you need more than just 272.
Read up a bit and see if you get the whole picture.
Latebloomer
89
4
27
Bro Izso.. just finish reading it before i ask the question bout the cam. Thats why im preferring for mild cam which u dont have to change any of the valve spring. Waiting for the seller response on the intake and exhaust degree
Latebloomer
89
4
27
hmm.. what brand is this. this is quite mild
pipercam brand.. but i just spoke with my pomen.. he said if wanna cam scare after installation need to change the injector and add piggyback somemore to support the cam. Lot of hassle. He advices me just to change cam pulley to adj one.
lsm1991
1,469
185
how much power is the pulley going to give you.... end of the day, im sure theres a target you want to hit, question now is how are you to hit said target
parakey
1,367
226
With adjustable pulley and without replacing stock camshaft, you gain a power increase of ZERO
You can only shift the powerband up/down the range but the manufacturer has determined the best setting with the stock pulley. In the end, you gain nothing but lose some money
Latebloomer
89
4
27
Then tell me is it worth it to install the cam tat i have shown above. What are the pros and cons after i install the cam
parakey
1,367
226
Btw, I am not saying this out of spite. I have adjustable cam sprockets on my car. Waste of time and money.
Dear Sifus,
My Wira 1.5 AT EFI 4G15 is impossible to start when it's hot. Sometimes it displays engine check light (code 21, coolant temp sensor). I changed the coolant temp sensor, spark plug, it's cables, distributor, fuel regulator, fuel filter and fuel pump. Daym that was expensive and unnecessary. I appreciate the DIY experience though.
I also did fuel pressure test and compression test. They are within range. Maybe Lancer repair manual was correct from the beginning. "When it...
