Sadly my area quite hard to sorce this type of bodypart.
So no choice.hahahahahaha
Btw bro, besides the orsen undercarriage shield, you can use some DIY ingenuity to protect the pulley and sensor from dust. Cut up some old fender guards and cable tie the crap out of it and surround the area. Well, that's assuming you have old fender guards. hahaha
Btw, has your mech tried replacing your ECU? Did he take out the ECU to see if any capacitors were burnt out or bloated? The sudden shut down is beginning to sound like an ECU issue
Last time my VR ecu died cannot restart already........lol
KHNG940413
668
56
johor bahru
Wira update
After switching to a new cam & crank sensor, unplug the ecu socket and cucuk balik and still......engine dead.
While the engine is dead and I push the pedal and start the car some time can start but the engine light went on so I go diagnose agn. It turn out the crank sensor issue still pop up.
The boss say the only way is to use back the original crank sensor from proton. And it ain't cheap.
I also quite not believe the boss say so i try how come the crank sensor keep got issue. So I start the engine and I try wobble the crank sensor.
And.....yes....the engine went dead.
So I guess is it really the crank sensor issue?
Even if I change the sensor will it work? I ask the question to boss the boss also cannot answer me.
Hahahahahahaha
parakey
1,367
226
Wira update
Hahahahahahaha
Check the position of the sensor in relation to the crank trigger (that gear thingie)
KHNG940413
668
56
johor bahru
This is my crank sensor position.
Tomorrow will go and source the original sensor.
If can ok la,if not I really wan to ditch the vdo and slam the mmc inside.
Is not like mmc will not have issue lah but less sensor issue is better for me to maintain the car at my rough working environment. My 2cent la.
parakey
1,367
226
Please check your connector and the wiring attached to it. Is the connector wobbly and not seating snug? Or does the wire feel stiff and not supple/soft?
Hi.. as u can see this is my 1st post... and im new to all this car stuff... i am just wondering can we actually DIY own diffuzers...
Reason:
To me is just a thin metal layer that is black in colour...
Cant we just use alluminium plate and black spray to do it???
Of course using the correct tools to Cut the alluminium plate..
and i find no reason spending more then RM300-RM1k to make this small thing for all 4 sides of the car....
Conts:
After DIY perhaps it might fail and falling...
