4g13 talks
Why don't you just ask your question? This is a forum mah, not everyone is going to respond to you instantly.
Latebloomer
89
4
27
ya ya sorry2.. still new in this forum.. anyways. Just changed my 4g13 carb to fi. Next wanna change to 1.5 block. Can use 4g91 block or 4g15?
Why you do FI only, should have transplant whole engine at once. Your FI wiring and ECU for 1.3L?
it's more cost effective to change the whole thing. Completely swap to a 4G15. The cost isn't that much more than changing the block only and both also need to re-register the engine anyway. Gearbox is the same so you don't need to touch that.
Latebloomer
89
4
27
Lets just say i still intend to change the block.. what are ur opinions
4G15 is as big as it'll go. MMC or VDO? Personally if you're not going for power I'd just stick back with another 4G13. Going to 4G15 block is not cost effective. You might as well bolt-on turbo the 4G13 for nearly the same price.
Latebloomer
89
4
27
Mmc. Mayb goin to use 1.6 stroker kit. Will it do any good
Latebloomer
89
4
27
wahlau... dude... 1.6 stroker + 1.5 block + installation = just change the engine cost.
hmm.. in that case mayb might change in the future.. for the mean time mayb some mild upgrade recommended? sorry ya im still newbie2 want play car
What sort of budget are u willing to spend?
Me personally wont waste on other upgrade if i have the fund for a better base engine. I can save more to mod the better base engine.
If u change engine in the future, u wasted money playing with the current engine...unless u got a bank note printer at home.
After using the Battery-free smartag that I DIY'ed before, I find it kinda
annoying and difficult especially if suddenly need to use the Smartag.:thefinger:
So, now I remove the wire and DIY a Switchable smartag that still use a battery. however, the battery will consume 0mA when it is switched off, therefore make it last longer.
Check it out!::smokin:
http://donsdiy.fotopic.net/c1526239.html
