1jz E36 BMW frankensteining
Dear All,
Just about 2 days ago, my legs were itchy and decided to rev the engine hard while stationary just to listen to its BOV sound. After a while, to my surprise, suddenly the engine transformed and the car just accelerate even crazier then before, the air intake suction noise is so soundly and car just sprints everywhere.
Until today i still can't figure out why the sudden transformation. Any one can help to clarify?
Thanks,
Ken
My reply will be some sort like bro. gunnerzz, revving the engine could have dislodge something, carbon piece stuck somewhere or cleared your injectors. You can see most mechanic when tuning, normal revs the engine......lol
Mitevo7
1,456
179
He's not wrong. JZs run hot. I'd go get a low-temp thermostat though.
I already have NTCL thermostat on standby, bought but havent install yet. The next oil change will install it. Hopefully that controls the temperature better.
Thanks,
Ken
Mitevo7
1,456
179
Funny enough the revving was done by me, my colleagues all came out to check what was i doing as it was 745 am in the morning. They thought i am driving stock standard 318ci all this while :rofl: Gotta love the stealth look.
Thanks,
Ken
Reactions: Izso
Thanks,
Ken
Under cover is best, like my VR now look like junk......lol
Mitevo7
1,456
179
Just modified radiator spare tank with a customized aluminium one. Adds blink to the engine bay. Also added a 500amp battery cable from alternator all the way back to the battery in truck. This rose the car's voltage to about 13.4-5v at idle will A/C on. Is this figure good enough?
Thank,
Ken
Thank,
Ken
That sounds like the more normal voltage (13.4 - 14.4V) on idle. Did you uprate the fan?
sweelt
Nov 6, 2016
2,306
248
Thank,
Ken
yup normal, as long voltage maintain. I get this figure too with battery relocated to trunk.
Remember to put fuse ehh...lol
Mitevo7
1,456
179
Nice , the next thing my mech suggested is to uprate the negative battery terminal, as far as i did, i only uprated the positive one and leave the negative terminal stock. Will it be better to change that as well or just leave it be ?
Thanks,
Ken
Thanks,
Ken
Might as well change it. The negative is grounded to the car chassis right?
sweelt
Nov 6, 2016
2,306
248
Thanks,
Ken
Use the same 500Amp cable (if u have balance) for negative too. Just connect to any chassis bolts around trunk.
Like sifu's mentioned.
Mitevo7
1,456
179
Just done it today. Hope the electricity supply is constant stable now.
I'm having problems with the front electric windows on my proton.
The passenger side window is very slow and sometimes stops all together.
The drivers side window jumps forward when it is going up and gets stuck. You have to hold it vertical while putting it up. Which is annoying as it requires two hands and traps your fingures.
Is there anything I can do without buying new motors.
Cheers
