1jz E36 BMW frankensteining
Mitevo7
1,456
179
3,163
You make it sound like your cars a disco at night when you drive. Hahaha!
Haha !! My car is gauge free !! I don't even know what boost am i running currently. My weird electrical issues before are dimming lights, slow rolling power windows, weak response, RPM constantly died on itself. Now all the above sort of solved, headlights still dimming, my mechanic recommend me to convert to LED as old style Halogen takes alot juice.
Thanks,
Ken
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
Thanks,
Ken
no no nonononoonononono...
dont shove any aftermarket led/hid bulb into stock halogen headlamp....
a very big no...
gain glare for not improving any of your actual driving light needs....
do atleast projector retrofit..even the cheapest mini H1 bi-xenon (hi-low) projector would be a much better upgrade than replacing halogen bulb with led/hid...
a very big no...
Yah! halogen reflectors does not work with led bulbs..........:smokin:
Mitevo7
1,456
179
3,163
Not quite, i installed it on my Lancer with H7 Halogen reflector, the brightness and distance covered is great and passed every JPJ roadblock at night !
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
u never knew how many ppl in the car from oncoming traffic cursing you..
try drive up to a flat wall and see your headlight beam pattern...was it on the left or the right kind of beam pattern in this picture
even on halogen reflector...the oem original good condition headlight still do have obvious "cut-off" line visible like on the right... and good hotspot in the middle near the cut-off line...
if the cut-off line is blurry and many light streak shining upwards, means thats the glare...and total not acceptable to be used on the road...
**cut-off line pattern depends on LHD/RHD and or EU or DOT pattern...
**example of cut-off line pattern:
1- RHD EU \___
2- LHD EU ___/
3- RHD DOT -----\____
4- LHD DOT ____/-----
this applied to reflector based and projector based headlight...
Also what color temp light you using? 4.3K below should be fine, higher I am sure cannot pass. My friend use halogen bulb 6k already kena.....lol
Mitevo7
1,456
179
3,163
4.3k :) ... the beam is tilted slightly downwards ... i don't need range but wide angle of the beam.
Thanks,
Ken
Mitevo7
1,456
179
3,163
Hi All,
It's been quite a while since my last post, good news to bring is i have rectified the RPM cluster intermittent turned off issue, just some messed up wire connections, but paid 150 smackers to get it all fixed up.
Mods done:
1.) Front, 343 mm disc rotor with OEM M3 brake caliper, rear stock system but upgraded brake pad and disc rotor with made in Germany brand (forgot the damn name)
2.) Front 26 mm adjustable ARB, rear 23 mm adjustable ARB (should be Eibach due to i got it out from a junked E46).
Tuning done:
1.) TPS readjust and realigned - higher and more stable idiling, better throttle response and slightly improved acceleration
Verdict:
1.) Braking power is superb and no visible sliding at the rear, most people with upgraded front brake system will experience this if they leave the rear brake system untouched.
2.) Steering turns sharper with higher precision into and out from corners, lesser oversteer symptoms and very stable rear end. High speed turning is like on rail eventhough i am on shitty tyres.
3.) Acceleration improved again, turbo boost seems to be more optimized for some reason.
Next Mods:
1.) Enable sequential mode - 800 smackers
2.) Better tyres - Unknown smackers
Thanks,
Ken
  • Like
Reactions: Izso
Mitevo7
1,456
179
3,163
1- RHD EU \___
2- LHD EU ___/
Sorry to reply this late, i think its more to the right but a little to the left, i would say 70% look like the right beam. I even looked at it while having my Lancer driving behind me to check the beam, it seems pretty acceptable and not bright as shit like old times HID.
Thanks,
Ken
Next Mods:
Thanks,
Ken
Tyres if okay, use until you feel uncomfortable with them.......lol
Got budget smackers and wallet clearer also......hahhahhaha
Mitevo7
1,456
179
3,163
This freaking tyre is all good but with minor vibrations on steering wheel, this sort of tyre need onwheel balancing which around my area doesn't have and i am too cheap to pay for balancing the tyre for over 20 bucks. Haha
Are your rims a perfect fit to the hub? Did you install center cone?
Previously I had this problem also. The tyre shop boss where i do my balancing, he always centralized the rims for me. Later on he manage to measure and find me some center cones. Nowadays no problem at all with balancing vibration.
On wheel balancing is good, but problem is, every time you need to remove your wheels for any repairs, the balancing runs and need to re-balance. Now on Off wheel balancing, I have no problems at all.....
Mitevo7
1,456
179
3,163
I am using BMW original rims for E46, and no i didn't install any center cone. Some tyres like Falken Ziew 914 will never be balanced off wheel, it has to be done on wheel. This shitty Membat Passion tyres are good for grip but shitty in terms of comfort.
Thanks,
Ken
Thanks,
Ken
ZE-914 are Falken Ziex mid tyres only, should try Falken Azenis range FK510
Hi,
Anyone has any idea how the insurance coverage is going to be if we do a auto->manual or manual->auto conversion to the transmission?
My auto box is giving me a headache so I was thinking of a replacement with a manual gearbox.
I know the re-sell value is going to be bad if I do that but my major concern is insurance.
The insurance policy stated chasis and engine number but I didn't find gearbox number on it. :hmmmm:
Anyone has this kind of experience before?
Please share...
