4g93 Mivec Turbo Waja project(Many pictures be warned)
Nightstalker1993
267
130
Subang Jaya
Wonder if after loctite, later want to remove the bolt, can it come off?
just check their site,got 2 type;
1.type only require manual tool.with a bit more force of coz.
2.type require heat to loosen the bolt.260 degree of heat.
Walao I susah2 find link give you all never read merr, got 4 types la walao. Buka link and read laaaa :laugh::laugh:
Habis lah, the sprocket, camshaft and the attached seals
So that's why they don't recommend Loctite Red for stuff you actually plan to open often haha
These things don't typically come loose on their own, do they?
it would come loose..especially if not overly tighten (damaging the thread and pulley) with super aggressive driving...
especially with current "affordable" stuff....
Nightstalker1993
267
130
Subang Jaya
Sup guys, been some time since I've updated this.
Not much had been done/happening on my car as I have a motorbike and also a Volvo S80 now so I rotate between the 3 vehicles. Last Saturday I managed to hit the dyno though, and here are the results, before my accessory belt decided to say goodbye. 235hp and 276nm of torque on a Dynokraft dyno, whose numbers are pretty understated, similar to Mainline's numbers. If you see the chart the highest run I did was around 245hp, but that run was knocking and I had to dial back on the ign timing to avoid knock.
Also for my own future reference, the code for the alternator and power steering/aircond belts are 5PK1300 and 4PK780
Nightstalker1993
267
130
Subang Jaya
about the same figure with me at 1 bar...nice nice...looks like s80 getting most of the tlc now..hahaha
Yours 2L, and yours should be more torque kot. Mine 235hp at like 7k rpm, yours should be peaking at a lower rpm I think? Want to push to 1.2bar wan but the belt snapped so tak jadi tune for that. Also using RON95 so was encountering some knock quite early, else can push for more power wan. You tune on what grade fuel?
marsha1l_v6
666
130
543
i dont know where i put my dyno sheet, cant recall the torque . peak hp around 5k ish rpm and peak torque around high 4k rpm, thats why i limit my rpm at 6.5k rpm.
running and tuning 97.
Nightstalker1993
267
130
Subang Jaya
Fuhhh nice la peak torque 4k RPM. Mine peak slightly higher at 5K RPM, but pulls alot longer kot, since peak HP is at 7000RPM and even above that still the HP doesn't drop off that quickly. i suspect my downpipe might be a restriction as I am using the original EVO downpipe, and also the fuel quality... But damn reluctant to run on RON97 :laugh:
not bad... mine 1.1bar 247whp/307nm torque on awd .driver:
Mmmmm nice one la stock standard boost, no need pening pening weird ass problems like me, just simple reliable power :biggrin:
standard engine and turbo..
but not running non standard boost level...
ANNNDDD i have to redoing almost everything the previous owner jackass mechanic...one example... i found more stripped bolt than the good one while working on it recently...
Which should make u even more confidence with that ride...it survived multiple stripped bolt, surely it can take a beating.
Nightstalker1993
267
130
Subang Jaya
wahh, so my car is almost the same power level as a subaru with increased boost level haha
Ok la, at least you found the bolts before it started causing an issue
I'm buying adjustable pulleys for my Colt Gti 4G93 DOHC with CAI and exhaust 2. 1/4", searched topics in the forum but have found.
Want to know what the best setting to increase the peak power at high rpm?
Can increase the peak power of the 140hp @ 6500 rpm for a rotation greater than 7000 rpm?
How many degrees do I need to forward the admission and how many degrees late to escape, have a higher peak power at high rpm?
Looking forward to the best setting.
