Add-on turbo onto 4G93P MIVEC
ZamS
ZamS
212
Dear All & Old Timers
I'm planning to upgrade my engine. Currently, I'm driving MIVEC 4G92 and already upgrade with 4G93 putra engine-block. Planning to bolt-on TD04 turbine. Just want to share with you all, what are the things I have to change and look into during setting-up the engine.
Waiting for your kind reply. Tq.
ZAM
gsrTurbo9166
gsrTurbo9166
958
yo bro
if u must maintain ur mivec wiring in order to make the mivec functioning
then u must change the injector to a bigger cc
need to change the gasket
the exhaust system
important is the ECU setting
jzhost
jzhost
279
very important is to check ur comp. izzit too high, else you'll get knock all the way
get gsr manif. and a td04 twin fin
not sure 4x450cc injector enough for u not cause mine enough for my 1.6 mivec turbo with bigger turbo
bigger i/c to get cold air so can help on without retard timing on low boost
get ps air fuel enhancer to monitor peak air fuel mixture
ps fuel enhancer and boost cut to make ur ecu loves boost and add more fuel
maybe get a ps mivec controller, to adjust mivec point open maybe somewhere around 4k?
anywhere to get better answer try call drager racing, i like the monster they built for me.
p/s if can dont use emanage, and run extra injector, trust me... call andy and tell him zth member mivec turbo intro 1.
