[DIY] Brake pads and disc rotor change
cvkit17
2,884
1,354
Need to add one more thing after installing everything.
- Start the car and give the pedal a few more pumps until it's tight.
I've seen one too many idiots who forget this and drive off immediately after changing only to realise brakes are not ready.
That's the first thing to do before releasing the hand brake hahahahaha
C99D-MMC5537
287
78
1 thing that very important to do while replacing brake pad (which most mechanic never do) is to lubricate both the caliper guide pin with hi temp silicone grease. This to makesure that both inner caliper (piston side) and outer slide evenly whenever u apply brake. I just killed my brand new jun e-slit rotor n bendix metal king when only the piston side pad totally worn out and scratching the rotor but the outer side still very thick.
Kevinho
94
Puchong
Guys what about greasing the backing plate and metal to metal contact points with copper antiseize ?
Is that necessary ?
Is that necessary ?
not absolutely necessary but it helps a LOT in dissipating heat, even force distribution (to some extent) and overall brake stickiness (sorta).
yeah. Myvi calipers I can remove and dismantle everything under 10 minutes.
Kevinho
94
Puchong
Yeap, that's right guys.
We should clean the caliper pins so that it won't seize up.
Later didn't clean will eat one side of the brake pads
sweelt
Nov 6, 2016
2,306
248
TS may i hijack sikit.
Anyone heard of Kugen brand brake pads ?
sort of made in malaysia iinm.
Why go for unbranded? I google go to a blog with no info at all.....lol
Wait for Trestor Advantage, maybe coming in 2019 but not sure when...:confused:
sweelt
Nov 6, 2016
2,306
248
ok ok ...wait for trestor
becos the pricing of kugen not so unbranded lah...hahaha
There's one mechanic recommend me to buy an advanced cam spoket(wondering if correct spelling or not) which act as an "add-on" device at the timing belt device.
Not sure how it works but he claimed it will improve car's speed,performance and fuel comsuption as well.He charge me for RM380 for it.
Anyway,anyone come across such term or not and what actually it does?
Please help :X-:
