Since Alza handles like a boat, some say even worst....
Supra_Fanatics
20,673
3,998
I think you should try to reduce the weight of your body first.
:rofl: :rofl: :burnout:
---------- Post added at 03:34 PM ---------- 6 hour anti-bump limit - Previous post was at 03:33 PM ----------
u all win liow lor, no nid say liow lorrrrrr
Bila drag with my kancil 660cc vs Alza :biggrin:
YellowFlash
308
34
Jb
Actually I feel the handling of the Alza is pretty decent even in the stock trim considering that it is a mpv on 15” stock rims with 185/55 Silverstone tyres. I have taken my Alza Advance up to Genting and Cameroon highland and it definitely handles better than the CX5 on genting’s road.
However, I believe there’s quite a fair bit of improvement that can be done to improve the stock Alza’s handling and also my driving experience. Some of the basic mods includes:
- aftermarket brake pads
- slotted rotors
- SS brake hose
- larger rims (16 inch) to hold thicker tyres
- better performance tyres with wider width
- rear UR anti roll bar
- front UR strut bar
As the car is not daily driven and often under utilise, I do not intend to spend on bigger items like BBK or Coilovers.
- slotted rotors
- SS brake hose
u dont need bigger rim...
just go with 15" with 7jj is enough atleast to use 195/50 or 205/50-15 performance tyre
stock suspension...but with both front and rear biggest UR ARB
YellowFlash
308
34
Jb
Ideally I don’t even want to change rims and just upsize to wider 15” tyres but I am not sure how much thicker can the alza advance stock rims accommodate. Are those tyre size for 15inch common? Just worried there are not much choices for the 15 inch... and ideally, if you are changing rims, you’d wanna upsize too.
ixeo
4,788
3,080
KL, Malaysia
You can put lipstick on a pig but it’s still a pig.
My bad For confusing you guys. By thicker I mean wider tires.
haha, actually was confused because initially thought thicker for wider, but your next sentence mentioned wider.....lol
195/50 is quite common but not as common as 195/55. 205/50 is less common and more expensive. 15" performance tyres most go for Michelin PS3 or Bridgestone RE-003 or Hankook V12Evo2.
YellowFlash
308
34
Jb
Haha, I didn’t realised that I interchangeably used thicker and wider till your confusion.
Ah, was thinking the the tyre size may not be that common and it will be expensive. Good to hear that 195/50 is a common size since that’s the recommended upgrade from 185/55 (if I recall correctly).
195/50 is smaller by 1.45% and 195/55 is bigger by 1.88%, both can be used, so depends what you want out of them.More towards handling then 195/50, more towards comfort then 195/55. But actually 205/50R15 is best fit, only 0.26% bigger but less choices and more expensive....hahaha
We have here with us a brand new Toyota Vios today. From our experience of working on countless Toyota(s), we always had the impression that Toyota had the best factory paint job. Likewise to the car we have with us today.
Upon arrival, we did a walk around the car to inspect for any obvious damages...
