Twin turbo a 4cylinder engine (1big and 1 small turbine)
Hi all,
Nothing to do try to do some research online but seem a bit blur here.
Let say if we have K3VETT with 1 ori IHI RHF4 turbine for pickup and another with bigger size for end power, what will be the advantage and disadvantages ya..
or we change to one IHI RHF3 and another one bigger..
Thinking of this since if small turbine no end power and big turbine will lag..
Any know please share ya:rock:
look into subaru legacy twin turbo setup...1big 1small
not easy to install/fabricate and certainly not easy to tune also
ixeo
4,788
3,080
KL, Malaysia
ixeo
4,788
3,080
KL, Malaysia
The latest Miata is specifically tuned with body roll to improve mechanical grip....
Tuned body roll != rolling like a boat.
You ever been in a boat? Cause boat's roll around in the waves based on, well, the waves, you have no control over it.
Nightstalker1993
267
130
Subang Jaya
Well, speedboat pretty stable :laugh:
What I meant by tuned body roll means it has quite a decent amount of body roll and is done on purpose to improve mechanical grip
ixeo
4,788
3,080
KL, Malaysia
I am not sure if its done on purpose for the sampan (have to ask the engineers), but i can tell you there's no grip whatsoever from the roll, and no control.
Kevinho
94
Puchong
Thanks, I try my best to keep it simple, and that image really does help understanding the system greatly.
Also can watch this video, the explanation on the video is superb.
VGT and Twin scroll is nothing new, both pretty much have the same goal which is to expand the turbo's efficiency range. But still out of reach of the mainstream production cars yet due to most probably the high cost for a VGT turbo designed to withstand the heat of a petrol engine, and also the complicated control strategies required to operate the VGT mechanism. If you can't wait, you can get a Porsche :laugh: Also, the more moving part, the more chance of problems. I've seen the VGT vanes of a VGT turbo get stuck before so that's another thing to ponder as well.
Twin scroll turbos works by dividing the exhaust pulses, introducing the scavenging effect in a way and reduces interference between the pulses thus improving the engine as well as the turbocharger's efficiency. Since twin scroll turbos work by dividing exhaust pulses, the manifold design is of utmost importance and for a common 4 cyl, cyl 1 and 4 will be paired to 1 scroll while cyl 2 and 3 will be paired to the other scroll. If you install a single external wastegate on the system by combining both scrolls, you pretty much negate the benefits of a twin scroll as mixing between the cylinder pulses can then occur since you had basically combined the scrolls. A proper wastegate system on a twin scroll setup would require two wastegates. On a stock Evo 4+ turbo for example, there is actually 2 wastegate flappers operated by a common actuator so the gas really does stay divided all the way until after the turbo.
For more reading material on twin scroll turbos, can read a few links here
http://www.bmwblog.com/2010/01/02/twin-scroll-turbo-system-design-explained/
http://dsportmag.com/the-tech/twin-scroll-vs-single-scroll-turbo-test-the-great-divide/
https://www.rx7club.com/single-turb...s-single-scroll-vs-twin-scroll-turbos-903210/
so really, if possible, get a twin scroll turbo :laugh:
No it is really completely different. Twin charging as in 2 identical sized turbos, main purpose is to reduce turbo lag by reducing inertial mass, but still suffers from choking up top. but even that seems to be phasing out now with more efficient turbochargers being introduced. Those people with RB and JZ engines which came with twin turbos are converting to single turbos and getting very good gains.
Compound charge on the other hand, as the video I attached describe, is really like running 2 seperate turbos, one for the low end and one for up top, vastly increasing your powerband. It's slightly different than staged turbo on certain production car where there are actually flaps or valves blocking/rerouting the gas flow while compound charge really is just suck air through this turbo and push air through the other turbo :laugh:
Teach us your ways Senpai !
Entering its third year on the trot, the Asian Auto Fuel Efficiency Awards is still the automotive industry’s sole awards recognising fuel efficient vehicles and the country’s oldest automotive magazine recently honoured the most frugal vehicles of 2010.
A total of 57 awards in 19 categories were handed out to various manufacturers in the hopes that it would spur them on to develop and introduce more...
