myvi 1.3 first gen cant accelerate above 120 km/h
No i think the problem was caused because my s flow (jian hang) and mid swirl bullet (kent wong exhaust) both have the function of storing backpressure in the exhaust system n cause too many pressure in the exhaust system not allowing the pressure to exit smoothly n my rpm cant rise smoothly.... :burnout: if im correct la :biggrin::biggrin:
But S flow also straight through muffler, only it return and then out again as in S. Why got so much back pressure?
Triple Y
37
the mid bullet n the s flow both got store back pressure
because when im using the same s flow on my kancil also got the same problem because the exhaust guy install a tube in the mid bullet n cause my kancil rpm not running smoothly after removing the s flow n replacing with another mid bullet the power is better
mean if want use the s flow (jian hang) mid bullet must be normal one not swirl type
It doesn't "STORE" backpressure la. Backpressure is when there is resistance for the exhaust to exit la. Like I already told you - remove the bullet lor.
And for exhaust to cause speed issues like that - your exhaust system must be pretty damn restrictive!!!
ixeo
4,788
3,080
KL, Malaysia
Stock car can go faster than his "modded" car. So he spend money to make his car slower.
Not extractor then, have strangler......lol:rofl:
Triple Y
37
The s flow was taken out from my previos kancil n the myvi stock exhaust system was having worn out gasket n stuck muffler.... that why i changed it...
Red Bull Racing’s Sebastian Vettel won last week’s Formula One opening round at Australia by a massive margin and without the aid of KERS. However, he will be running it for the Malaysian round next weekend as the long straights of Sepang suites the use of KERS.
Another change for this season includes the use of an adjustable rear wing that with its pitch being adjustable by the drivers. Some of the...
