myvi 1.3 first gen cant accelerate above 120 km/h
what i found out so far is that my myvi will delay the shifting when at full throttle... i need to release the pedal for it to shift
On Full throttle the gear will delay shifting until attain higher speed....:driver:
alcyon
800
153
543
My old 91 saga overhauled in 2004 still can do 150 kmh at 5000rpm in 5th gear. Bog standard, just been using syntethic oil since overhaul. the PCV valve hasnt clogged yet.
ixeo
4,788
3,080
KL, Malaysia
Top of my head, assumption... both your brake calipers jammed?
ixeo
4,788
3,080
KL, Malaysia
Triple Y
37
I think i found out the problem already. problem cause by too much back pressure in exhaust system nothing to do with my gearbox :biggrin::biggrin: after changing to straight flow can reach 140 easily.
thank you for all ur help :adore::adore::adore::adore::adore:
Triple Y
37
No i think the problem was caused because my s flow (jian hang) and mid swirl bullet (kent wong exhaust) both have the function of storing backpressure in the exhaust system n cause too many pressure in the exhaust system not allowing the pressure to exit smoothly n my rpm cant rise smoothly.... :burnout: if im correct la :biggrin::biggrin:
ixeo
4,788
3,080
KL, Malaysia
Got picture of your s flow? Curious how it looks in a myvi.
There are a lots of huge famous system with fantastic features suitable for workshop now days (of course pricing usually will be also very fantastic ).
But what if you just require cheaper, simple and straight forward system that able to help you provide following information:
1. Service Record History of each Car / Vehicle.
2. What is the last service millage of each car / Vehicle.
3. Which Car still owe you payment and how much is it.
4. What is the price changes of particulare stock...
