How to remove burnt oil stains on SS exhaust extractor
parakey
1,367
226
Now looking at your extractor, the 2 to 1 joint before the flexible bellow, does not look smooth/straight. A bit bent at an angle......:smokin:
If you look at the stock unit, there's a kink after the flexible joint. I think the bend which you are referring to is to avoid that.
y2188
441
42
28
Your engine bay has a lots of space between the header and the radiator fan. Can put one of those fancy extractors with long runners. Mine doesnt have such space
Mine is even worse haha had to grind off the fan bracket a bit to clear the runners
Interesting that stock 4G93 headers are actually 4-2-1 configuration. I thought most manufacturers will use a short 4-1 header to save cost.
even 4g92 sohc also stock came with 4-2-1.... but with shorter runner....and casted
RENESIS VIII
7,063
950
Ipoh
Means it is still not as effective as an aftermarket 4-2-1 with longer runners?
I heard Wira SE comes with 4-2-1 as well but I think it is differently designed compared to what I installed.
If you look at stock exhaust, 2 to 1 start at the curve in front on the engine. Aftermarket joins at under the engine near the flexible bellow....:driver:
RENESIS VIII
7,063
950
Ipoh
Yeah. But why stock ones join so early? Save costs again?
Does this kind of joining early setup offer any advantage over aftermarket? Or aftermarket is totally better in every aspect?
Stock as far as I know is tuned to be average in everything, power, consumption etc. etc.....you would have heard people complain loosing low end, gain high end and all those stuff, right?
RENESIS VIII
7,063
950
Ipoh
Yes I have. But after installing my 4-2-1 extractor, I can say that I felt no losses anywhere. Is better than stock in every aspect so far. There is a very slight increase in exhaust sound but I am okay with that.
it was effective to some extend...
for daily stock use and better fc....YES...
but for speed freak and different engine powerband tune, definately not... coz out of their designated workscope....
RENESIS VIII
7,063
950
Ipoh
If aiming for top end power, 4-1 should be better. :biggrin:
kuntauasli
178
13
There is a product called "magic stain" made by Yoshimura. it is 10x lesser effort than autosol. I highly recommend this.
Ferrari unveiled their latest speed freak of a creation during the 2012 Geneva Motor Show, only to reveal a freak of nature in terms of horsepower: all 740bhp from under the hood of a V12 monstrosity that will catapult the car from 0-100kmh in just 3.1s!
<!--more--> Apparently, the...
