215/45R17 was around RM330, that is why 235/40R18 for RM350 is d*mn cheap.....Wah like that 17' should be around RM300...
Will consider this tire as mine needed to change soon.
Your V12 are UHP tyres mah! Those you mentioned are extreme tyres, very rough block pattern will be nosier even when new...
Yup, for daily can use right up to Max performance that is next highest after UHP. After Max will be extreme, which for me will be better for track rather than daily.....I see....So UHP still have some comfort element la....Got it
Well you can FB the shop. And contact him to check price. He is very friendly. Mr Patrick
Yup, the main concerns with using extreme category tires for daily use are:Yup, for daily can use right up to Max performance that is next highest after UHP. After Max will be extreme, which for me will be better for track rather than daily.....
Oh you also use 17' on your X? What size, 225/50/17?
Camry 17" should be 215/55R17Mine ori 17' camry rim as I mention earlier, size i'm not sure whether is 215/50/17 or 225/50/17.
But the tire changed before, if not mistaken should be either 215/45/17 or 215/50/17.Camry 17" should be 215/55R17
225/45/17 is too small for Mark X, your car will be lower by over 1 cm and the fender gap also increased by the same. Should use 225/50/17 like mine now. Minimum is 215/50/17 which I used last time but 225/50/17 is better. Even better if you use 17x8.5jj rims or at least 17x8jj, and then use 245/45/17.But the tire changed before, if not mistaken should be either 215/45/17 or 215/50/17.
Next change upgrade to 225/45/17.
215/45R17 is too small, even 225/45R17. Have to be 215/55R17 or 225/50R17....But the tire changed before, if not mistaken should be either 215/45/17 or 215/50/17.
215/55/17 is a bit too big/thick already. 225/50/17 or 245/45/17 are the perfect sizes for 17' in Mark X.215/45R17 is too small, even 225/45R17. Have to be 215/55R17 or 225/50R17....
But 215/55R17 is standard Camry tyre size woh! My friend using.....215/55/17 is a bit too big/thick already. 225/50/17 or 245/45/17 are the perfect sizes for 17' in Mark X.
Yes but 215/55/17 is slightly bigger compared to std Mark X size while the 215 foot print is just a bit too narrow for Mark X. Additionally the sidewall looks too thick so not nice and handling is already too soft/a bit wobbly.But 215/55R17 is standard Camry tyre size woh! My friend using.....
255/40/18 look nicer... Time to change rim.Yes but 215/55/17 is slightly bigger compared to std Mark X size while the 215 foot print is just a bit too narrow for Mark X. Additionally the sidewall looks too thick so not nice and handling is already too soft/a bit wobbly.
225/50/17 is just nice while 245/45 is a bit smaller in diameter but the wide foot print is very good for grip, and looks good on lowered cars.
I use to have 225/40/18 but this V12 Evo2 i took 235/40/18.....Is even nicer....Looks bigger too although same profile....255/40/18 look nicer... Time to change rim.
Yes of course, 225/45/18 or 235/45/18 front on 18x8jj and 255/40/18 rear on 18x9jj is perfect. But you'd need lightweight rims to keep the weight down.255/40/18 look nicer... Time to change rim.
235/40 is of course bigger, coz the sidewall is really taller/thicker:I use to have 225/40/18 but this V12 Evo2 i took 235/40/18.....Is even nicer....Looks bigger too although same profile....
