4G92P jerking
jebatdex
430
18
Skudai, Johor
Hi sifus
I can feel the small jerking especially when cruising at low speed (40-60kmh). I have replaced cable plug and distributor, but problem persists. Can anyone suggest what should I do next? Spark plug is relatively new.
jebatdex
430
18
Skudai, Johor
How do I say it.. jerking, not vibrating... small jerking like the engine is lack of fuel/iginition..
jebatdex
430
18
Skudai, Johor
Fuel filter changed before?
I think changed 2 years ago.
---------- Post added at 01:41 PM ---------- 6 hour anti-bump limit - Previous post was at 01:36 PM ----------
For fuel pressure, you have to ask ur mechanic to check unless you have fuel pressure regulator and for the air flow , you can take out the maf sensor clean it with maf/ carb cleaner
So, maybe I need to install the fuel regulator. From what I know, usually fuel regulator installed to those high performance car where they want to set for more fuel for more performance, and no effect if installed on normal car (correct me if im wrong).
For the maf sensor, I dont have the cleaner, so better just bring to mechanic and let him clean it, so dont have to buy the bottle of the cleaner. I never see the maf sensor cleaned during servicing before.
jebatdex
430
18
Skudai, Johor
I tried to look for CRC MAF Cleaner at Ace Hardware Bukit Jelutong last weekend, but they do not have it. Have some CRC Contact Cleaner, Degreaser, etc, but not MAF Cleaner. Is CRC MAF Cleaner is the only product that I can use to clean the MAF? Any others? Or maybe can only use pressurised air to remove dust?
7,514
contact cleaner also fits the purpose
30,002
MAF sensor quite fragile, so not too strong if use pressurized air
jebatdex
430
18
Skudai, Johor
Also, will try with contact cleaner. I see in Ace, quite expensive, 1 bottle RM80++ huhu :hmmmm:
---------- Post added at 10:08 AM ---------- 6 hour anti-bump limit - Previous post was at 10:08 AM ----------
OK.. noted on that. Thanks
7,514
look in decent hardware shop...plenty of other brand of contact cleaner....
30,002
What? RM80 per can for contact cleaner. Should be around RM15 to 20 can get dy.....
avex00
Feb 12, 2013
12
Selangor
Ace sells all imported stuffs, went thru a few oceans to come over..price doubled and best is..Made in the USA, hoping its quality after pouring in wont kill yr car...LMAO
30,002
ACE mostly in shopping center, nice air con and environment for you to shop so all that is costed in. Just like that day I bought some fertilizer for a friend. At Aeon is like RM10 per kg but I got them at my hardware store at 4kg for RM20 only....
anyone in melaka can just borrow my contact cleaner.....then belanja me roti canai...kawtim..
so far i only used it twice after buying it.
hi guys i plan to send my W207 (E Class Coupe year 2010) to upgrade its entertainment system . I found out about this place after passing through an advertisement while reading Top Gear magazine.
These are the upgrades that I plan to install :-
Reverse camera
DVD player with USB
GPS
Do you guys think MYR5,000 is reasonable price for these installations? and I was told they would integrate well with my COMMAND system.
hope to hear from u guys.
I have inquired Exotic Mods...
