4g92p stock ecu
dking91
121
11
518
pekan
hi, im using 4g92p sohc ecu..it is possible to tune my stock ecu and check the AFR/ignition problem??
coz i hv a problem wif my car when speeding at 100+km/h, got soung like bell,"krenngg krengg" and i felt the power lost and less responce of the throttle..
:bawling:
what i hv done to solve the problem so far:
1: change distributor
2:change cable plug
3:overhaul
now the problem still cant be solve... so i suspect the ecu maybe have prblem wif AFR/ignition
(sry not really good in english)
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
emanage
but first go check with obd scanner first the ecu got error code or not
dking91
121
11
518
pekan
update:
i went to tuning workshop yesterday, the result are
1:no o2 sensor and the wiring have been bypass(previous owner)
2:ignition advanced 11 degree.cannot be adjusted even rotated the distributor(mechanic said wiring issue) also the cause of knocking
3:tps reading cannot be set also, only at 400-500++..it should be 700++
4:injection reading 2.6-2.8m/s.according to tuner it should be 2.3-2.4m/s
5:valve "bocor" the reason y trompet sound like motobot(just know about it)
solution suggested is change to other wiring and ecu+o2 sensor...
can i use adjustable campuley to overcome the TOO advance ignition timing problem??
alfi
Jul 26, 2011
18
bro dking91, would you let us know where is the tuning shop? my 4G92P have been very thirsty lately and thinking to retune my ecu but dont know any shop.
dking91
121
11
518
pekan
i do at dungun..the tuner stick obd scanner then check injector reading,tps,ignition...
any tuning shop that hv obd can tune i think....
E-Tech
1,115
256
3,183
Johor
one of my plan b4...but require a lot of things.. head, 4g91 carb distributor,ACP to get the right setting, cable plug... :)
now im stick with sohc..
Your ecu not stock I guess that is why
trouble. Now RPM cut is at......?
GEFORCEXTREME
151
13
:bawling:
2:change cable plug
3:overhaul
That sound, I think that is knocking. I don't think it is the ECU that is problematic, I'm thinking that it could more probably be a sensor problem. MAF sensor, borrow one from others and try to see if it helps? Try adjusting the distributor too, try to rotate it to make it a little retard.
---------- Post added at 06:03 PM ---------- 6 hour anti-bump limit - Previous post was at 06:00 PM ----------
I think better stick with SOHC, its troublesome to convert.
1) Wiring is not compatible. That's why you need the 4G91 carb distributor.
2) 4G91 carb distributor is old and rare, what happens if it kongs?
3) "HEARD" ppl said you can skim the SOHC distributor to fit, but "HEARD" it is also not reliable.
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
:bawling:
2:change cable plug
3:overhaul
sorry i missed some question on you...
what engine did u run? 4g92mivec? 4g91? 4g93 sohc?
because as far as i know...for 4g92p doesnt have o2 sensor....
dking91
121
11
518
pekan
sry i hv not noticed people reply on my post... my engine is 4g92p... the knock still there.. when the problem occur, i still using the stock ecu..
now i hv upgrade the ecu..rev cut 9k rpm..the 1st problem after upgrade is the car jerking "sengguk2" like not enough fuel.. so i use adjustable FR and the pressure that required to reduce the jerking is 4kg/cm2++!! i changed the fuel pump,injector 240cc and now the AFR still at 4kg/cm2... this evening i try set it 4.5 the response good no jerking but knocking still there..i cant breath behind my car, the exhaust smoke too stink...no black smoke yet....hmmmm got headache to solve the problem...
GEFORCEXTREME
151
13
1) I recommend get a stock 4g92p ecu and put back in, check for any errors. Do not use ecu from other cars first.
2) Borrow another maf sensor and try if it is better.
---------- Post added at 04:02 PM ---------- 6 hour anti-bump limit - Previous post was at 03:52 PM ----------
Some 4g92p dun use o2 sensor, some used. My use, it is a UK spec car, so I assume its for emissions control.
---------- Post added at 04:10 PM ---------- 6 hour anti-bump limit - Previous post was at 04:02 PM ----------
Anyway, when you said your car was overhauled, then the workshop dun notice valve bocor? Just open the head to see...
GEFORCEXTREME
151
13
Can you take a video of the car at idling (open bonet, start car, record video for one or two minutes), upload to Youtube or something? That way, we can understand better, also I want to know how the valve bocor sounds like. Sure you have a video camera or smartphone right?
dking91
121
11
518
pekan
i will try take video... this video taken after changing the mufler from previous trompet hks hi power-proton satria 4g92 sohc - YouTube
current sound after upgrade ecu and AFR will take later.. but just using old version of mini galaxy :(
the formen said got valve bocor after checking each injector using scanner
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
PETRONAS SYNTIUM TEAM TO RACE IN JAPAN’S SUPER TAIKYU ENDURANCE SERIES
PST Media, 12 January 2007
After two successful campaigns in the Asian Touring Car Championship (ATCC), the PETRONAS SYNTIUM TEAM will be taking part in the Super Taikyu Endurance Series in Japan from 2007. The announcement was made during the SYNTIUM lubricant launch at the Japan Auto Saloon Exhibition at the Makuhari Messe Conference centre.
